LI 195 Will not tick-over
Postby Bobf » Thu May 25, 2023 9:35 am
Hi All recently build a Series 3 Li 150 Special. Upgraded to a 195 and installed a YSN PHBH 28 Carb. Jetting is as follows:
Pilot - 55
Needle - X13
Atomizer - AV266
Slide - 120
Choke - 200
Problem: The engine starts fine with choke, I turn of choke after about a minute. But have to maintain engine running using throttle. If I close throttle off, the engine stops.
Have tried the tick-over screw fully in and fully out but it makes no difference to the tick-over. I know this is not right.
Any ideas on what I can try to get it running correctly?
Bobf
Re: LI 195 Will not tick-over
Postby bookertmgs1 » Thu May 25, 2023 10:28 am
Is it a RT kit ?
If so - look on the MB tech site - clear jetting instructions on there or the RT page on facebook as loads of info on there
Your own stated jetting figures look a litte wrong - specifically the slide & choke.
I suspect the 200 figure is the needle valve - which should be 300 or 350 - thats the control that refils the float bowl
Slide should be 40 or 45 - thats the round metal thing that the needle fits through & sort of controls the air into the carb with the throttle cable
bookertmgs1
Postby martyn dwane » Thu May 25, 2023 11:37 am
are these copy carbs using genuine Dellorto Jets ?
martyn dwane
Postby Bobf » Thu May 25, 2023 3:44 pm
Yes the cylinder conversion is an RT 195
I incorrectly listed the jetting! Correction is as follows:
Idle/Pilot 55
Needle X13 (second position)
Atomizer AV266
Main 120
Slide 40
Float Red Tip 200
Choke (not known)
Thanks will give MB site a look.
And Yes the carb is using genuine jets.
Bobf
Postby Toddy » Thu May 25, 2023 4:17 pm
Hers one from an RT I built last year for someone
28mm PHBH/Scootopia Clubman Filter
Pilot 55
Choke 70
Main Jet 115
Atomiser AV266
Slide 40
Needle X7 P2
Float valve 300
Postby Bobf » Thu May 25, 2023 6:39 pm
Hi Toddy
Will try using your setup.
Bobf
Postby Toddy » Thu May 25, 2023 6:40 pm
Bobf wrote:Hi Toddy
Is your throttle cable adjusted ok seems strange your not getting a tickover with the screw is the air screw set ok ?
Postby Bobf » Mon May 29, 2023 1:00 pm
High All. Well Toddy fixed the necessary jets to your configuration.
Start fine but still will not tick-over, just cuts out when throttle is closed!
Have another Lambretta owner coming over this week to see if he can offer some advice.
Bobf
Postby Toddy » Mon May 29, 2023 1:01 pm
Bobf wrote:High All. Well Toddy fixed the necessary jets to your configuration.
Have you tried the adjuster on the top of the carb it may be a bit of slack in your cable ?
Postby Storkfoot » Mon May 29, 2023 2:47 pm
If it likes ticking over with the throttle on, it likes being richer than it is. As the pilot you have doesn’t appear on the weak side, I’d suspect you may have an air leak somewhere.
Postby MickYork » Mon May 29, 2023 7:53 pm
Do you have an air filter fitted ?
Postby Bobf » Wed May 31, 2023 10:14 am
No at the moment open mouth but will be fitting a foam filter direct to carb.
Bobf
Postby bookertmgs1 » Wed May 31, 2023 11:20 am
Storkfoot wrote:If it likes ticking over with the throttle on, it likes being richer than it is. As the pilot you have doesn’t appear on the weak side, I’d suspect you may have an air leak somewhere.
+ 1
have you done a leak down test ? That would be my 1st action at this point.
bookertmgs1
Return to Carburettors
Users browsing this forum: Bing [Bot] and 52 guests
