Dumb question alert
Dumb question alert
Postby Lord-Spanner » Wed May 24, 2023 7:48 am
With the motor not running, in gear and clutch pulled in, with the rear wheel off the ground, should I be able to rotate the rear wheel? or have I a problem some where like stuck plates etc etc :roll:
Lord-Spanner
Re: Dumb question alert
Postby lofty » Wed May 24, 2023 8:54 am
it should move but likely with some stiffness due to inherent clutch drag, clutch plates could be stuck, but not necessarily a problem as they may just need freeing off if not used for a while..
if its completely jammed, clutch issue (could be as simple as cable) or gearbox issue likely..
I guess if you shove it hard enough it should move the crank/piston..
lofty
Postby Lord-Spanner » Wed May 24, 2023 10:03 am
OK thanks for the advice and speedy reply :mrgreen:
Lord-Spanner
