Stripped thread.
Stripped thread.
Postby Stu » Tue May 23, 2023 7:16 pm
Is there an easy fix for a stripped chaincase level plug thread?
Thanks.
Stu
Re: Stripped thread.
Postby Littlewheels » Tue May 23, 2023 9:54 pm
Hi,
I don't think there's an easy fix here. I would get it welded up and re tapped.
Littlewheels
Postby Knowledge » Tue May 23, 2023 10:40 pm
I suppose it depends on how badly it is damaged.
I was able to buy a tap for the three holes in the chain case recently. It was less than £8 delivered via eBay. It might not be the best quality but i only wanted it as a “thread chaser” to repair a damaged thread so it is never going to be tested in thick steel.
The tap is M16 x 1.5.
Postby hullygully » Wed May 24, 2023 9:13 am
if there's still some thread there then I'd use some plumbers white thread tape
Postby Fast n Furious » Wed May 24, 2023 6:38 pm
If the thread is completley goosed, then you could consider drilling out to 18.5mm and tapping the hole to M20 x 1.5 (M20 electrical conduit tap) then use an electrical M20 to M16 conduit reducer. The 18.5mm drill may not be part of your armoury, so you could just consider filing it out carefully with a round file.
Lapp cables make a nice reducer complete with a sealing o-ring or you could just use a regular brass one and loctite it in permanantly.
You should be able to find the tap and reducer on Fleabay or your local electrical stockist. ;)
