LD Timing
LD Timing
Postby Solid Air » Mon Apr 24, 2023 6:09 pm
I know / think the LDs weren't static timing originally. But, what would be a good point to set static timing on my GT125? I'm using a Varitronic ignition but with a BGM static CDI as I became aware of issues with the full Varitronic, which is why I've gone for a static set up.
Many thanks, Mark
Re: LD Timing
Postby jbcollier » Tue Apr 25, 2023 2:54 pm
Went and had a look. Nice kit!
It has squish and probably makes quite a bit more power than stock. Set the timing to 17° to 19° BTDC depending on set up. Large carb, extractor exhaust = 17*. Stock carb and exhaust = 19°.
jbcollier
Re: LD Timing
Postby Solid Air » Tue Apr 25, 2023 8:07 pm
Thank you jbcollier. I'm at 17° with the standard exhaust, so in the right area.
Cheers, Mark
Return to Pre 57
Users browsing this forum: No registered users and 34 guests
