Hard starting check list?
Postby vegansydney » Tue Apr 25, 2023 11:12 am
I just pulled a Lambretta out of storage after a year and it's not starting. It has spark and is getting fuel but won't kick over. So far I've done the following:
-replaced CDI
-replaced HT lead and cap
-replaced carb and jetted to spec
-replaced flywheel (SIL for balanced BGM)
-drained fuel and refilled with fresh
-checked choke is seating correctly
-took off fuel cap (no vapor lock)
-isolated the ignition switch (green wire)
-checked compression (good)
-performed a leak down test (holding air)
Before I annoy a friend, what else should I check LT coil? Air gap on flywheel? I'm a jet lagged wreck so I'm sure I've overlooked several things.
vegansydney
Re: Hard starting check list?
Postby bookertmgs1 » Tue Apr 25, 2023 11:53 am
Thats quite a list so far.
- is the plug wet when you have checked it after kicking it over ?
- checked all your other connections inc regulator and earths
- Throttle cable not being held / stuck somehow
- should start regardless - even if timing is wrong
- its basic - but have you tried some easy start down plug &/or mouth of carb - just to get it to fire
- checked exhaust not blocked.
bookertmgs1
Postby vegansydney » Tue Apr 25, 2023 12:25 pm
Thanks for the prompt response! In answer to your questions:
-the plug is wet after kicking over
-regulator connections are fine as is the earth to the flywheel cowl/mag housing
-throttle cable is opening slide easily---I checked this several times
-I tried easy start several times, but forgot to mention in the original post.
I've not checked the exhaust. Will do tomorrow. Anything else I should check?
vegansydney
Postby Rich Oswald » Tue Apr 25, 2023 12:29 pm
I suppose there's a chance your rings could have gummed up and stuck after parking it up.
Postby vegansydney » Tue Apr 25, 2023 12:43 pm
Rich Oswald wrote:I suppose there's a chance your rings could have gummed up and stuck after parking it up.
Interesting point. I performed a compression test as I though the same, but discounted it after a high reading on the gauge after a few kicks.
vegansydney
Postby duncan1958 » Tue Apr 25, 2023 5:35 pm
I would put the flywheel that you have taken off ,back on and give it a try.
It's remotely possible that the pick up height is not compatible with the BGM flywheel and needs adjusting.
Check the outputs of the stator with a ohms meter,although not conclusive it's a good start.
duncan1958
Postby MickYork » Tue Apr 25, 2023 6:02 pm
Finger in suppressor cap to confirm spark.....painful but foolproof :mrgreen:
Postby vegansydney » Wed Apr 26, 2023 12:03 am
duncan1958 wrote:I would put the flywheel that you have taken off ,back on and give it a try.
Thank you! Will do. Appreciate all the recommendations.
MickYork wrote:Finger in suppressor cap to confirm spark.....painful but foolproof :mrgreen:
I can see it sparking, don't know if I need to 'confirm' it :lol:
vegansydney
Postby srx600 » Wed Apr 26, 2023 8:45 am
Old fuel ?. I have a four stroke single which, if left for long periods, will will only start if I empty the fuel bowl.
srx600
Postby Leotech » Wed Apr 26, 2023 9:11 am
Is it flooded?
Did you try fuel and choke off and hold it flat out and kick it or push it in second gear ?
Leotech
Postby bookertmgs1 » Thu Apr 27, 2023 8:43 am
any progress ?
- as above - check its not flooded. Clear the barrel, dont turn fuel back on and then try easy start again
- Amazed that nothing happens with easy start - any sort of spark should make it at least do something - even a splutter
- whipping the exhaust off should give you access for a partial look at the state of the rings
- Maybe swap the stator for a known good one - even if yours is sparking
- Checked plug gap
bookertmgs1
Postby jonw » Thu Apr 27, 2023 10:12 am
"It's remotely possible that the pick up height is not compatible with the BGM flywheel and needs adjusting"
+1
jonw
Postby hullygully » Thu Apr 27, 2023 12:12 pm
could still spark with low stator readings bud
Postby vegansydney » Fri Apr 28, 2023 1:12 am
Managed to get it started and running, but still none the wiser of what was the exact cause. :oops:
My good friend (and mentor extraordinaire) and I spent some time going through everything yesterday. First thing we checked was the stator and readings were completely fine. I believe it was a combination of choke cable sticking occasionally and possibly the 17°ignition timing making it hard to start.
It's a very mild tune Suzuki 185, Clubman, TM24 and now it's running so I can put some klicks on it and see if I can work out the exact issue.
Huge thanks for all the help and advice! :D
vegansydney
Users browsing this forum: Baidu [Spider] and 37 guests
