Now moved on to sorting out the wiring and cabling before fitting the ignition and finally putting the engine in the frame. This picture is just to show my attempts at hiding the indicator wiring under the leg shield beading.
coaster wrote:That looks tidy Paul, you shouls see the birds nest of wires under my horncasting![]()
Storkfoot wrote:
Scooterslag wrote:Storkfoot wrote:
Very neat, I do like what you've done , Paul
dickie wrote:Yes, that might be easier. Certainly easier to adjust as doing it my way would mean ordering and soldering in new resistors if you wanted to adjust the speed.
If you connect both indicators to the warning light, they'll both flash like hazard warning lights when you try to indicate. So put a diode in series between each one and the warning light, then they'll be fine.
