Nord lock washers
Nord lock washers
Postby stephena » Wed Apr 12, 2023 7:03 pm
Not sure we’re to put this question but here goes. Is it important/ necessary to use nord lock washers on sip tubeless alloy wheels? Has anyone tried anything different.? Every time I remove a wheel it seem at least one of the halves disappears with the other small lambretta bits which have made a bid for freedom at various times. Thanks.
stephena
Re: Nord lock washers
Postby ULC Soulagent » Wed Apr 12, 2023 7:39 pm
Never liked the nordlock system and I use the Mb’s stuff for the sip rims 8-)
ULC Soulagent
Postby gizmo » Wed Apr 12, 2023 7:43 pm
ULC Soulagent wrote:Never liked the nordlock system and I use the Mb’s stuff for the sip rims 8-)
. +1
gizmo
Postby dickie » Thu Apr 13, 2023 4:55 am
Nord locks are easily the best way of maintaining bolt tension if used properly. That means not using against anything that can rotate, for example a plain washer on the other end of the bolt. And also not used against paint.
They can be a bit of a pain, and are less effective once they've been on/off.
Personally on wheels, I use nylocs. They don't maintain tension anywhere near as well, but my main concern with wheels, is simply not coming off. If they slacken slightly, you'll notice.
Postby Solid Air » Thu Apr 13, 2023 8:23 am
Think the idea is great, but I have had them fail while riding when I've used them on wheels, so stopped using them after that.
Postby Rich Oswald » Thu Apr 13, 2023 10:48 am
I have a box full of Nordlocks and change them every time I remove a wheel.
Postby hullygully » Thu Apr 13, 2023 10:57 am
they shouldn't fail IF used the correct way round & oiled up
in the oil & gas industry in the Nth Sea etc......... its now common to replace spring washers with Nord Locks.
Postby Solid Air » Thu Apr 13, 2023 11:06 am
Both previous comments are fair points. Changing them every time is the gold standard I would say, but they are supposed to be able to be reused a few times as I understand it.
I have not seen any mention of needing to have them oiled up before, and don't doubt their effectiveness, but I lost my confidence in using them on wheel studs through my experience with them.
Postby hullygully » Thu Apr 13, 2023 11:34 am
fair point kid, but I've re-used mine several times with tyre changes etc.............except when they've made a bid for freedom :roll: or I've used excessive force & snapped 'em :? (not correct torque setting)
Postby Toot » Thu Apr 13, 2023 1:20 pm
These threads do make me weigh up the cost of replacing such parts every time, as opposed costs saved when re-using?
Nord-Lock Washers can be bought for a couple of pound for 4.
Bit like always replacing an inner tube each time you change a tyre, an inner tube is around £10 on top of the £30 or so for the tyre.
The potential cost of either of these parts failing as they have been re-used more than once.......??
I know what my preference is.
Toot
Postby dickie » Thu Apr 13, 2023 5:34 pm
I only use stainless ones as I "borrow" them from work, ours are all for offshore, hence the stainless.
The oil must be for carbon steel ones to stop them rusting?
Postby Toddy » Thu Apr 13, 2023 9:05 pm
dickie wrote:I only use stainless ones as I "borrow" them from work, ours are all for offshore, hence the stainless.
Do you take them back when you have finished with them ? :lol: :lol: :lol:
Postby Leotech » Fri Apr 14, 2023 9:50 am
What I don't like about Nordlock system is the thickness, you loose about 3 mm of thread, A pal has some SIP rims on an older 1960's vespa and with the Nordlocks there is only 3 or 4 threads left on the cast in studs for the nuts to hold the wheels on. I don't know which shop fitted them for him but id not be happy riding it.
I just use nylocks with loctite and change for new nuts often.
Leotech
Postby hullygully » Fri Apr 14, 2023 10:10 am
no chance of changing his studs then bud? :shock:
Postby Swat » Fri Apr 14, 2023 10:42 am
I run AF tubeless rims & after an incident on a coast 2 coast where I parted company with the back wheel due to loose wheel to hub fasteners, & having spent most of my working life in Airframe structures test, I went down the 'aerospace' route
K-lock stiffnuts - from Demon Tweeks https://www.demon-tweeks.com/uk/demon-t ... ut-243560/
you can get them from E-bay etc but I'm always a bit nervous of their real quality & provenance
NOTE: Based on my Aero test experience, they only retain full 'stiffness' for 3 or 4 installations/removals so I tend to replace every couple of years
Swat
Postby hullygully » Fri Apr 14, 2023 11:55 am
£2.59 each Swatty :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Postby Toddy » Fri Apr 14, 2023 11:57 am
hullygully wrote:£2.59 each Swatty :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
No price on safety ;)
Postby hullygully » Fri Apr 14, 2023 3:13 pm
with those nuts, the last few threads are a slightly shallow i/dia, hence their locking ability, so with constant use they'd wear certain parts of the studs' thread, :shock:
I'm sticking with Nord Locks on SIP wheels ;)
Postby roli150lam » Mon Apr 17, 2023 1:48 am
merlin motorsport sell high temp k-nuts as well as standard.price are similar to demon tweeks.
roli150lam
Postby Rich Oswald » Mon Apr 17, 2023 11:35 am
Mark N Sven on Facebook is selling Nordlock washers at a very decent price.
