GRTDKAD wrote:RB250, 30mm Dellorto VHSH, AF Mammoth, AF
62mm Race Crank 116mm rod
Front sprocket 20T, Crown Wheel 47T
AF Road 6 plate clutch, AF CLO5E 5-speed box
Tornado exhaust
I have read that that It is a higher revving exhaust, but if you're happy how it rides that's all that matters surely?
Goes well, though I’ve had a few folk tell me that I shouldn’t have a tornado on there.
nastro azzurro wrote:Why not the tornado?
I’ve had to put an old tourer on mine after the supertourer split beyond repair.
Supertourer was far better than the tourer and was considering a tornado but don’t know anyone using one…
jonashford wrote:super tourer
Tornado exhaust
GRTDKAD wrote:Simon - the attached was the go-to spec from Ben at Rayspeed for the RB25 and VHSH30 set up.
*My carb was worn so more or less everything needed replacing!
Hope you’re not too far off:
DQ267 ATOMISER
30MM/ 34MM DELLORTO MAIN JET 170 SIZE 6MM
FLAT SLIDE FOR DELLORTO VHSH 30 VHSH NO. 40
U16 NEEDLE
DELLORTO NEEDLE CLIP
DELLORTO VHSH30 CHOKE JET 50
30MM/34MM DELLORTO PILOT JET 50 SIZE 5MM
30MM STEPPED CARB RUBBER
30MM DELLORTO TO TS1 / RB 40MM ID TO 35MM ID
