Got myself a nice little Senorita
Re: Got myself a nice little Senorita
Postby Scooterslag » Sat Feb 18, 2023 6:20 pm
Intrigued to see this build, in all my time in scootering - I've little to nothing to do with shaft driven lammies . I've ridden a couple but never worked on one or ever had any spares for them. Look forward to your updates. Paul :)
Postby Solid Air » Sun Feb 19, 2023 9:42 am
Thanks Storkfoot and Scooterslag, glad you like the updates. This engine is very different to what I'm used to also and so very interesting for me too. The bevel gear set-up and engineering around the crank and drive shaft is a real contrast to later engines, I'm very grateful to whoever came up with the series 3 engine concept! :lol:
Postby Solid Air » Wed Mar 22, 2023 6:46 pm
Making steady progress with Minty's tidy up. Lots of T-Cut, steel wool, elbow grease and the ipod on shuffle. Very therapeutic.....
The engine is nearly done with its new crank fitted. A slight delay in proceedings when sizing up the new kit to find the engine is actually a 125cc, not a 150, and the stud spacings (mk1?) are different to the GT150 I had bought, oops :lol: but very chuffed with the signwriting I had done on the side panels 8-)
Postby Scooterslag » Thu Mar 23, 2023 3:25 am
Looks spot on, the patina has a great pattern ( if you know what I mean) not just a rusty old dog , like the sign writing as well, be great to see it completed and running. 8-) Paul
Postby Covboy » Thu Mar 23, 2023 11:09 am
Looking great mark!
Postby Solid Air » Thu Mar 23, 2023 11:53 am
Thank you both.
Yes the patina is coming through nicely Paul and the body work is all very solid, it's just in need of a really good clean up. I'm hoping to have everything done in time for a day trip out to the LLC Chiltern Hills Challenge, fingers crossed.
Postby Solid Air » Fri Mar 24, 2023 6:27 pm
I can't take credit for rebuilding and fitting the crank, refitting the bevel gears and shimming them up correctly, that's what best mate Viv, fellow Team Solid Air rider is for, but that's the hard bit done. I'll be fitting the GT top end next week and I'm just waiting on one of Richard Taylors new Boost exhausts.
The crank has a bolt on web on the nearside which was a total mare removing, and eventually the rod was cut to extract it as the bolt was stuck solid. The web is removed for fitment and then trued in situ.
Postby Knowledge » Fri Mar 24, 2023 9:44 pm
I think you could make a contribution to the Oily Rag chain of Jetset article from your work here Mark
Postby Solid Air » Fri Mar 24, 2023 10:03 pm
Knowledge wrote:I think you could make a contribution to the Oily Rag chain of Jetset article from your work here Mark
What, a bluffers guide to Shaftys?! :lol:
Postby Solid Air » Thu Mar 30, 2023 8:41 am
I've been busy getting Minty's engine ready to run. It's been very interesting getting to know this new type of engine, with the help and guidance of my best mate Viv, admittedly he did most of it! ( I can highly recommended Raven Motorcycles near Darlington. Not that I'm biased ;) :D )
The clutch is a little different to the series 3 type ( the 3 cork plates were in soak )
The piston is from a Yamaha DT100, can you feel the power?
Measure twice, cut once. A perfect fit for the Richard Taylor designed barrel
We did find that the con-rod on the Casa crank just kissed the spigot, so a touch of fettling needed to fix that
The finished article
Postby hullygully » Thu Mar 30, 2023 9:32 am
you're doin an ace job there bud
Postby watty-rugby » Thu Mar 30, 2023 10:29 am
Super job mate!
watty-rugby
Postby Solid Air » Thu Mar 30, 2023 4:49 pm
Thank you chaps, it's getting there.
Postby Andy B.L.C. » Fri Mar 31, 2023 9:27 am
Looking great, best you get your finger out Mark Jet Set deadline is looming! :lol:
Andy B.L.C.
Postby dickie » Sat Apr 01, 2023 10:52 am
Very nice and a refreshing change too.
Why have you chosen solid mount carb?
Postby Solid Air » Sat Apr 01, 2023 11:39 am
Thanks Dickie. The GT kit comes as a solid mount set up as standard.
Postby Solid Air » Wed Apr 12, 2023 9:25 pm
Here is where I'm up to with Minty the LD
Yet more cleaning done
A handy little rack and a cheerful little box to carry a spare wheel, oil, plug spanner and the like, but not much more
The engine is back in the frame
Legshield badges rejuvenated and years of road grime removed
Before...
After...
And I got Mike Bonnet to whip up a 3D print of a carb / air filter mount that I thought up, to utilise the original filter cover
Some air filter foam will cover the opening but the air box will be empty inside and probably be rotated 180° for panel clearance, and to receive some fresh air through the side panel grill
I've decided to now use 3.00 x 10 S83 tyres on the 10" conversion rims, rather than the larger 3.50 to help with gearing. Apparently the LD is around a 4.8 FDR and with a big jump between 2nd and 3rd. The S83s shouldn't be too drastic a change for the gearing but should help with handling and grip over the originals.
Also, I have heard that there are some issues using a Varitronic ignition with its variable timing. Scooter Surgery do have a static Stratos ignition but I had already bought the Varitronic. However, Cambridge Lambretta now sell a BGM CDI which will convert the Varitronic to static timing, so I am giving that a go, fingers crossed.
Any ideas how to put a bit of tarnish on the new flywheel grill? I wondered if a soak in water and sodium bicarbonate (or similar) might do the trick, rather than scuffing it up with steel wool?
More to follow, as it happens. Thanks for reading this far :)
Postby Toddy » Wed Apr 12, 2023 9:28 pm
Great work Mark thanks for the update
Postby Scooterslag » Wed Apr 12, 2023 10:45 pm
Brilliant stuff, I like the 3D printed carb mount, very neat solution . 8-) Paul
Postby dickie » Thu Apr 13, 2023 4:47 am
Looking great.
For the flywheel grill, just splash in salty water and/or vinegar then leave outside for a few days. Alternatively, alloy wheel cleaner left on a bit too long should do the trick.
Users browsing this forum: No registered users and 88 guests
