by shawit » Tue Mar 21, 2023 11:04 pm
I've tried without success to remove the steering locks from 2 spare handlebars I've had sat on the shelf for 30 years. I have the keys for the 2 locks. I've removed the grub screws which I thought were the only things securing the locks. Neither handlebar has any paint restricting movement. I've heated the handlebars with a bunsen burner and repeatedly applied 'Plus Gas'. But the locks will not budge. Have I missed something? / Any suggestions gratefully received. Cheers
shawit
by hullygully » Wed Mar 22, 2023 10:32 am
try a nail or any other pointy instrument down the screw hole & try to gently knock it out after heating, otherwise remove ickle ally ring which should give you lock access.
by Tractorman » Wed Mar 22, 2023 3:12 pm
If you have the key put it in the lock and turn it partly around, you can them pull on the key.
Users browsing this forum: No registered users and 81 guests
