12v Halogen headlight bulbs.
Postby Storkfoot » Thu Mar 09, 2023 1:01 pm
The one on the left has good connections to the bulb holder but no shroud, resulting in dip and main being the same. The one on the right has appalling connections but does have a shroud inside.
It’s a while since I have bought any. Does anyone have any recommendations please? Ideally good connections, well made and a shroud.
Re: 12v Halogen headlight bulbs.
Postby martyn dwane » Thu Mar 09, 2023 3:10 pm
why not put some extra solder on the connections ?
or
https://www.readspeedscooters.com/xenon ... 2265-p.asp
martyn dwane
Postby Storkfoot » Thu Mar 09, 2023 7:01 pm
martyn dwane wrote:why not put some extra solder on the connections ?
or
True. I may end up doing just that.
The one on the right, which failed after next to no miles, had clearly had solder put on but a couple of the blobs had fallen off.
Have you used the Reedspeed one?
Postby roli150lam » Fri Mar 10, 2023 8:37 am
Pedparts Uk.reputable shop.they have some in stock
roli150lam
Postby Tractorman » Fri Mar 10, 2023 9:59 am
Has anyone tried LED headlight bulbs?
Postby ULC Soulagent » Fri Mar 10, 2023 10:03 am
Tractorman wrote:Has anyone tried LED headlight bulbs?
Yes, they very good although depends if ya want to spend £30 for a proper one and not the ting tong crap ;)
ULC Soulagent
Postby Storkfoot » Fri Mar 10, 2023 10:15 am
roli150lam wrote:Pedparts Uk.reputable shop.they have some in stock
Thanks, Roli. I can see the LED ones but no Halogen ones.
https://www.pedparts.co.uk/product/5581 ... -led-ba20d
I’m not fussed about the LED ones, to be honest. I have a Vape ignition with good lights.
Postby roli150lam » Fri Mar 10, 2023 10:50 am
tap on the photo of the ba20d 35watt bulb it'll show you the halogen bulbs
roli150lam
Postby martyn dwane » Fri Mar 10, 2023 12:31 pm
martyn dwane
Postby roli150lam » Fri Mar 10, 2023 12:53 pm
martyn dwane wrote:https://www.pedparts.co.uk/product/745/headlight-bulb-ba20d-upratedhalogen
Thankyou Martyn Dwane
roli150lam
Postby Storkfoot » Fri Mar 10, 2023 1:16 pm
Thanks, lads. I couldn’t see for looking :D
I have ordered a few.
Postby missing lynx » Fri Mar 10, 2023 7:27 pm
I get mine from Halfords
Postby Fast n Furious » Mon Mar 13, 2023 4:10 am
These 5 minute ting tong bulbs will not focus onto the road correctly on dip beam and will likley only serve to blind oncoming drivers..
The right ones for the job can be found at:-
https://www.dynamoregulatorconversions. ... s-shop.php
Users browsing this forum: Baidu [Spider] and 26 guests
