What would his timing retard to at this speed
nsaints wrote:What would his timing retard to at this speed
You'd need to find the technical information on the ignition system, specifically the ignition curve ideally on a graph indicating the timing at given revs
Use that along with the Lambretta Gearbox analyser (free .xls to download via a google search) to know what revs for given speed to know the timing at a given speed
you would need to know what gearbox, sprocket ratio's you are running though..
Wack wrote:I think the Vespa chart is exactly the same for a Lambretta as it’s the same system but with a different stator backplate.
Users browsing this forum: No registered users and 39 guests
