Running Lean/Air Flow issue?
Postby Bilko » Sun Feb 19, 2023 2:08 am
I’ve just put together a Gori Sport 200 iron barrel in my S1 running a Jetex 22mm through a BGM “high flow” airbox, I can’t seem to richen it. Very lean and I’m wondering if the set up with the Airbox and carb doesn’t work well or am I missing something?
Carb jetting: Main jet 118 then up to 125, Pilot jet 50, choke jet 45, 200 slide.
I’ve managed about 90 miles with short runs at 30mm h, but it doesn’t sound good when changing down.
Leak testing and all seems fine.
Initially I thought I’d sorted it because of slow fuel flow and I put a fast flow tap on.
I would liked to have thought I’d have this sorted, but I haven’t used a set up like this in a long time and I’m quite disappointed with myself.
Bilko
Re: Running Lean/Air Flow issue?
Postby ULC Soulagent » Sun Feb 19, 2023 9:51 am
Bin the jettex Robert and go delly 25 ;)
ULC Soulagent
Postby Scooterslag » Sun Feb 19, 2023 10:31 am
ULC Soulagent wrote:Bin the jettex Robert and go delly 25 ;)
Yep Jettex's are too hit and miss, I've known a few people to get on with them ok but a lot more who couldn't ;) Paul
Postby Bilko » Sun Feb 19, 2023 10:35 am
Thanks for the replies.
Bilko
Postby MickYork » Sun Feb 19, 2023 11:43 am
Have you checked for an air leak now that it's running ?
Postby Bilko » Sun Feb 19, 2023 12:15 pm
Yes, used an inner tube so I could test the exhaust stub.
Bilko
Postby Leotech » Sun Feb 19, 2023 8:30 pm
Bilko wrote:I’ve just put together a Gori Sport 200 iron barrel in my S1 running a Jetex 22mm through a BGM “high flow” airbox, I can’t seem to richen it. Very lean and I’m wondering if the set up with the Airbox and carb doesn’t work well or am I missing something?
I had a Gori and it flew, was good for 70ish, Pulled 4.7 top gear jetted as below, Big bore pipe SH carb through airbox etc.
Main 130
Pilot 50
Choke 50
Slide -1
Atomiser-1
Air screw 1 turns out
Leotech
Postby Bilko » Sun Feb 19, 2023 9:52 pm
Main 130
Pilot 50
Choke 50
Slide -1
Atomiser-1
Thanks. Something definitely amiss then!
Bilko
Postby hullygully » Mon Feb 20, 2023 12:23 pm
Main 130
Pilot 50
Choke 50
Slide -1
Atomiser-1
DEFO up the main jet to a 130 bud, I've even got an armadillo air hose & a breathe sweet with an airbox like a swiss cheese
Postby Leotech » Mon Feb 20, 2023 6:02 pm
Main 130
Pilot 50
Choke 50
Slide -1
Atomiser-1
My air filter box was standard big hole type, but with the baffle out of the scoop and a hi flow filter, not the wire mesh type. I've just set my TV200 up and thats fairly standard cast iron 200 but with a AF big bore and a 22 carb and thats liking a 130 main currently, was a 132 to begin with, I think it will end up at 128 after a few more miles.
Leotech
Postby Bilko » Mon Feb 20, 2023 9:06 pm
Thanks.
Bilko
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
