martyn dwane wrote:Anyone tried these ?
https://www.ebay.co.uk/itm/124913387858
I have the H4 bulb holder conversion on my GP, so was thinking of trying these
coaster wrote:martyn dwane wrote:Anyone tried these ?
well they are certainly cheap and may well work ok but the problem with LED longevity is heat disipation. The expensive ones use eithe a tiny fan or an ally heat sink. I dont think those have either
Adam_Winstone wrote:A pal had read so much about the benefits of LED bulbs that he replaced every bulb with LEDs, then asked if I would be kind enough to have a look to see why he was, shortly afterwards, having so many issues with his lights.
When I investigated, he was using one of the high wattage output BGM stators. The combination of high output and little being used by the LEDs had burnt out (melted) a considerable amount of his wiring!!!
LEDs are great, as part of a well thought through and balanced system but not the solution to all problems!
Users browsing this forum: Majestic-12 [Bot] and 17 guests
