gaz_powell wrote:Theres a proper tool to do it.
It flattenes the pin on the rear.
Think ive seen one on ebay of late
Specialcase wrote:At last I can offer advice to someone
Lincoln Lambretta £40 follow their link to he eBay shop!
Storkfoot wrote:I follow Sticky’s page 202. Cam Lam do a cheap tool to open up the end to be preened over which I have. However, I find a centre punch followed by a small ball peined hammer to be better.
It is definitely a two person job and half the battle is getting the tags lined up with the panel holes.
Fast n Furious wrote:I cut down the pins first with my Dremmel.
Apply a clear double sided thin tape to the back of the badge. (Pain in the arse job with a craft knife)
Then, I get an assistant to hold a wrapped 7 pound hammer head against the badge face. The pin then peens over nicely using a punch ( with a degree of confidence )and doesn't rattle loose over time.
If the pins are too long, then they will likely just bend over when you try to peen them.
Fast n Furious wrote:Yes,
and has worked every time since.
You really do need that big weight behind it and pins shortened to the right length.
Users browsing this forum: Scooterslag and 72 guests
