Fast n Furious wrote:Lithium ions need battery management control to charge them safely.
Some batteries have the electronics to do this within the battery itself.
Lithiums don't like the high ripple current that is inherent with shunt regulated charging systems.
I recommend that you keep it simple and just use a small lead acid accumulator.
dickie wrote:Fast n Furious wrote:Lithium ions need battery management control to charge them safely.
I've found some 3.7V cells that I can fit nicely within an BECME housing I have, so if nothing else, they'll look OK.
They have protection in-built.
I hear what you're saying, and I agree, but I'm going to try it anyway, because I'm just like that. It usually works out, but sometimes I regret it![]()
Obviously, it will be fine initially, so any feedback I give will be close to worthless for at least a few months. At the moment, I honestly don't know the type of reg/rec I have, but I'd expect it to be shunt type. If it doesn't work out, I can change to a MOSFET in future. MOSFETs are standard fitment on late CBR600s and ZX-6R; probably a whole lot more, but I don't know for sure.
