Series 2 With Jet engine
Postby Storkfoot » Sat Nov 05, 2022 6:18 pm
Not literally a jet engine :D
One dry build has already been done but as I have spent months panel beating the front mudguard back into shape, I need to do another dry build before it all goes for paint in a few weeks.
Re: Series 2 With Jet engine
Postby dickie » Sat Nov 05, 2022 7:00 pm
Doing anything special with it, or keeping it standardish?
Postby Storkfoot » Sat Nov 05, 2022 7:19 pm
Nothing special. Stage 4 200cc and single seats.
Postby Cgt75b » Sat Nov 05, 2022 7:59 pm
Looks like a good project :D
Postby Storkfoot » Thu Nov 24, 2022 4:27 pm
More panel beating needed to match up the join between the mudguard and legshields. Taking off some more of the scabby paintwork in the footwells has shown a few pinholes too.
Postby Covboy » Thu Nov 24, 2022 7:59 pm
Nice
It must be an early one with the round horn cover hole rather than pear shape
My personal favourite
Postby Toddy » Thu Nov 24, 2022 9:43 pm
Didn’t know you was a panel beater Paul ;) nice scooter what’s the paint plans ?
Postby Storkfoot » Thu Nov 24, 2022 10:30 pm
I think it is quite early, 1960 anyway. Panel beating, well, I wouldn’t list it as a skill by any means :D I bought a cheap kit from Machine Mart a year or two ago. Sometimes it works, other times it doesn’t :)
Paint is going to be standard but not the dark grey panels it had originally.
Postby dickie » Fri Nov 25, 2022 8:18 am
Looks like a rather luxurious, spacious workshop you have there.
Funny how your envy shifts focus as you get older :lol:
Postby Storkfoot » Fri Nov 25, 2022 9:45 am
dickie wrote:Looks like a rather luxurious, spacious workshop you have there.
Early ‘70s, I’d guess, pre fab garage with uneven and cracked concrete floor. Very cluttered and, at this time of year, really cold. It does have windows and a radio though :D
Postby Storkfoot » Tue Dec 13, 2022 4:19 pm
Heater on in the garage. Working on a mock up of the indicators with a T5 style buzzer.
Postby Scooterslag » Tue Dec 13, 2022 9:42 pm
Interesting stuff- I'll be intrigued to see your indicator set up and switch/ wiring arrangement. Paul ;)
Postby Storkfoot » Tue Dec 13, 2022 10:32 pm
Scooterslag wrote:Interesting stuff- I'll be intrigued to see your indicator set up and switch/ wiring arrangement. Paul ;)
I’ll be pleasantly surprised if it works :P
Postby Storkfoot » Wed Dec 21, 2022 12:20 pm
The indicator mock up works :o
Reworked Honda C90 switch, relay from Vehicle Wiring Products, inline 15a fuse, buzzer is an aftermarket T5 one and the indicators themselves are Hella. They are the ones used on bar ends, more commonly. They’ll be fixed in this case.
I am no electrician so if anyone can see anything that is wrong or potentially dangerous, feel free to shout out.
PS. Apologies for the out of focus picture. I was suffering from shock that everything worked as it should :D
Postby gizmo » Wed Dec 21, 2022 2:16 pm
Nothing more satisfying than when you flick a switch and there's no bang, flash or just nothing and whatever works as you planned. Sheer delight :D
gizmo
Postby Storkfoot » Wed Dec 21, 2022 8:32 pm
gizmo wrote:Nothing more satisfying than when you flick a switch and there's no bang, flash or just nothing and whatever works as you planned. Sheer delight :D
:) The flasher didn’t work straight off but I quickly realised I’d made an incorrect connection at the relay. :D
Fitting the wiring neatly will present one or two issues as this scooter will not have a legshield toolbox to hide stuff in. Also, the metal indicator housing does not earth to metal so requires a short, but slightly unsightly, earth wire. Anyway, that’s all for another day several months away.
Postby dickie » Thu Dec 22, 2022 7:17 pm
Just one thing you might be better changing.
The primary job of a fuse is to stop wiring from burning out in case of a fault.
Depending on wire size, environment, insulation type etc, 15A needs something like 1 to 1.5 sqmm wiring.
I doubt very much that your indicator system draws anywhere near that much. I'd guess no more than 6A and that's being generous.
Do you know the wire crossed section?
So, I'd suggest a smaller fuse, namely 6A.
Like someone above said, you always get a little thrill when stuff works without going bang. I'm an electrical engineer and got excited yesterday when an electrical motor moved first time.e :lol: . I should be used to it after 40 years!
Postby Storkfoot » Fri Dec 23, 2022 1:42 pm
dickie wrote:Just one thing you might be better changing.
Thanks very much for this. I have used the wiring cables that came with the switch, fuse and buzzer. They are all different but none are what I would class as “too thick.” The fuse wiring looks thicker than it is as it has a cheap plastic outer which is a lot thicker than the wires it covers.
The cables to the indicators themselves are a thin gauge. I think it is this:
https://www.vehiclewiringproducts.co.uk ... -sq-16-020
I’ll drop the size of the fuse as you suggest. I was hoping someone would comment on that :D
Postby Storkfoot » Fri Feb 17, 2023 8:46 pm
Posted for no other reason than I like this slightly surreal picture :)
Postby Storkfoot » Fri Feb 24, 2023 1:55 pm
Top end received so I can finish engine to stage where I can do a leak down test.
