I've got all the parts collected to build an MB 6 plate clutch and it's high time I got around to putting it in! I tried out an external mic. How does my jetting sound? I think it sounds a little lean when I close the throttle after a fast run.
GP Kevo wrote: Do you think it's possible that the carburetor has worn over time? It's done a lot of miles an there is visible wear of the slide.
nickw wrote:GP Kevo wrote: Do you think it's possible that the carburetor has worn over time? It's done a lot of miles an there is visible wear of the slide.
Hiya Kev, hope you're doing well. We met at a petrol station, a few years ago on one of the Euros albeit briefly.
The problem with the Mikunis is the wear on the atomiser and needle . See link below. I was having all sorts of problems with one of my TS1 engines and bought a brand new Mikuni and this changed the behaviour of the engine for the better. I was told at the time if you're on a 58 then you need to be buying new.
viewtopic.php?f=6&t=6567
Good Luck
Users browsing this forum: No registered users and 55 guests
