by jonoy » Tue Sep 27, 2022 10:54 pm
Is the gear selector critical as in photo before fitting tie bar gear linkage as mine is pointing straight downwards
jonoy
by hullygully » Wed Sep 28, 2022 12:19 pm
can you get 5th gear?
by jonoy » Wed Sep 28, 2022 12:41 pm
I could but there was sloppiness in the cables.
I attempted to take it out by pulling cables through the trunnions but now when I select 1st engine stalls when pulling away, feels as though it’s in a higher gear and also 5th is non selectable.
jonoy
by hullygully » Thu Sep 29, 2022 11:25 am
could have cables wrong way round, it happens even to experts sometimes bud
by nickw » Thu Sep 29, 2022 11:59 am
hullygully wrote:could have cables wrong way round, it happens even to experts sometimes bud
Back to front and front to back lol
I had some problems setting my 5 speed up. I did find not only had I incorrectly adjusted cables but also the gear selector. Try using the gear selector without cables to see if the gears can be selected correctly. This will then let you know where the issue is likely to be - cable adjustment or gear selector adjustment
nickw
Users browsing this forum: Google [Bot] and 75 guests
