by Cosmic Wizard » Mon Aug 08, 2022 10:57 am
Good morning all, what are your opinions/thoughts on the spare wheel carriers that pick-up on the horncasting fixings?
Personally I don't like the idea of all that weight of the carrier and wheel hanging off the threads in the horncasting - not to mention the vibration.
I have been fitting the carriers that hook over the top, but the jigging/manufacture of my last two is a bit hit and miss.
Interested to hear your thoughts.
Cheers,
Jim
Cosmic Wizard
by alex_hughes » Mon Aug 08, 2022 11:12 am
I prefer the sort which hook over the top of the legshields and just use the lower fixings. better support in my view.
One think I do if bolting in to horncastings is to use 50mm grub screws with a dab of locktight on the end. Tend to use more of the thread in the horncasting than standard screws, and that extra bit of thread is normally in good condition. Obviously you have a locknut visible on the outside but I guess if you are adding a wheel carrier you are not going to be too anorakky ...
alex_hughes
by landybretta » Tue Aug 09, 2022 8:32 am
I also prefer the type that hooks over the legshields. The bottom fixing utilises the top bolts for the mudguard not the horn casting. Much better in my opinion.
landybretta
by superhooper » Tue Aug 09, 2022 5:45 pm
Never had a problem with them
superhooper
by Cosmic Wizard » Sat Aug 27, 2022 8:18 pm
Thanks for your replies
@alex_hughes : That's a really good idea using studs. Thanks for that
Cosmic Wizard
Users browsing this forum: Baidu [Spider], Google [Bot] and 59 guests
