Am I correct in thinking the arm gets flipped for reverse pull?
So from this
To this?
Storkfoot wrote:No, it stays the same way. Bottom photograph is right.
tv175lambretta wrote:To point out the bleeding obvious...
The brake lever doesnt know whether it is being pulled from the right or pushed from the left. The brake mechansim itself is completely unchanged so isnt suddenly going to 'grab' more when used in reverse pull (ie push).
The only difference to changing to reverse pull is a more direct cable routing leading to lower cable friction and therefore a smoother more sensitive 'feel' for the brake, with less pulling effort needed on the handlebar brake lever.
If the shoes are worn out, and there is a risk of the cam locking, that's the same either way you route the cable.
But if you want to keep loads of friction in the cable route thats up to you. If you like to pull harder for less braking effort, then keep the original. Why not introduce a whole extra 360 degree loop in the cable if its better that way?!
GExS wrote:On a related solution, I see Steelweasl the YouTuber that posts about Lambretta's, mostly good stuff, posted about putting a small pulley wheel near the hub lever to aid the braking. It looked to work on the video but I don’t quite understand the physics.
The best front brake set up I’ve ever had was using a reverse pull with a reshaped clutch level.
