Oiltek fuel gauge mounting?
Postby Lord-Spanner » Sat Jul 30, 2022 8:23 am
I have purchased an oiltek long range tank (it's like a piece of art work too) with a sender and fuel gauge as I don't like not knowing how much juice is left in the tank, so to those who have this set up how/where have you mounted your gauge? I don't really want a legshield tool box as that's where some are mounted so any other ideas/pictures please? :mrgreen:
Lord-Spanner
Re: Oiltek fuel gauge mounting?
Postby shane BBoys » Wed Aug 03, 2022 4:56 am
HI do not have a fuel gauge but how about having a bracket made and fix to the top of the leggies using a horn cast fixing the cable could then come up inside the horn cast?
Cheers Shane
shane BBoys
Postby Lord-Spanner » Sat Aug 06, 2022 7:37 am
shane BBoys wrote:HI do not have a fuel gauge but how about having a bracket made and fix to the top of the leggies using a horn cast fixing the cable could then come up inside the horn cast?
Cheers Shane
Yes Shane, I found a 52mm mounting pod on ebay that can be shaped to the legshield profile, just in the process of blending it in with a skim of filler after bolting it on, will post some pix when I've finished it. 8-) 8-)
Lord-Spanner
Postby shane BBoys » Sat Aug 06, 2022 10:37 pm
Cheers Shane
Please do
shane BBoys
Postby Lord-Spanner » Sun Aug 07, 2022 7:30 am
Here is one after mounting it.
Lord-Spanner
Postby Lord-Spanner » Sun Aug 07, 2022 7:31 am
and number 2
Lord-Spanner
Postby coaster » Sun Aug 07, 2022 9:32 am
Id be interested in the style of sender unit that oiltek use, Ive not had much success with the adjustable type :?
Postby Lord-Spanner » Sat Aug 13, 2022 8:06 am
coaster wrote:Id be interested in the style of sender unit that oiltek use, Ive not had much success with the adjustable type :?
I think the gauges and senders are acquired from a boating company, give them a bell and ask the question, they were very helpful when I spoke to them. 8-)
Lord-Spanner
Postby Lord-Spanner » Sat Aug 13, 2022 8:21 am
And a couple more pictures for folk who want to see
Lord-Spanner
Postby Lord-Spanner » Sat Aug 13, 2022 8:23 am
And again..............Not a a bad jobbie for an amateur :mrgreen:
Lord-Spanner
Postby gizmo » Sat Aug 13, 2022 9:47 am
Lord-Spanner wrote:And again..............Not a a bad jobbie for an amateur :mrgreen:
Tidy job there fella
gizmo
Postby Lord-Spanner » Sun Aug 14, 2022 7:23 am
Cheers gizmo, still in etch primer but see below for very nearly finished product with the gauge mounted....
Lord-Spanner
Postby Lord-Spanner » Sun Aug 14, 2022 7:31 am
Almost finished, just paint and trying to sorce a grommet for the cable
Lord-Spanner
Postby Lord-Spanner » Sun Aug 14, 2022 7:32 am
And again.....last one honest :mrgreen:
Lord-Spanner
Users browsing this forum: Solid Air and 8 guests
