shane BBoys wrote:HI do not have a fuel gauge but how about having a bracket made and fix to the top of the leggies using a horn cast fixing the cable could then come up inside the horn cast?
Cheers Shane
Lord-Spanner wrote:shane BBoys wrote:HI do not have a fuel gauge but how about having a bracket made and fix to the top of the leggies using a horn cast fixing the cable could then come up inside the horn cast?
Cheers Shane
Yes Shane, I found a 52mm mounting pod on ebay that can be shaped to the legshield profile, just in the process of blending it in with a skim of filler after bolting it on, will post some pix when I've finished it.![]()
coaster wrote:Id be interested in the style of sender unit that oiltek use, Ive not had much success with the adjustable type
Tidy job there fellaLord-Spanner wrote:And again..............Not a a bad jobbie for an amateur
gizmo wrote:Tidy job there fellaLord-Spanner wrote:And again..............Not a a bad jobbie for an amateur
