Warkton Tornado No.1 wrote:SIII shock absorber will fit straight in, no issue. In fact, it is a sensible modification & should give the transmission an easier life.
BTW. If anybody is unaware, the easy way to align the splines is to nip up the bolt 'just' tight then hit the cap with a mallet. if the mallet bounces, then alignment has been achieved. Usually, if not aligned, keep tapping & it usually has the effect of making the splines align. Then the bolt can be fully tightened with just another check to see if the mallet still bounces, as it should.
Users browsing this forum: No registered users and 55 guests
