kevspeed wrote:Sorry fellas, it's the black box for the SIP speedo.
kevspeed wrote:Speedo lights up, clock works, no speed reading, no rev reading, holding the button for 3 seconds to re set doesn't work, but pushing once for each function does.
I'm wondering if I have damaged something inside
kevspeed wrote:Brown lighting wire.
coaster wrote:kevspeed wrote:Brown lighting wire.
I have a Wassel DC system and my revounter is connected to one of the yellows
kevspeed wrote:coaster wrote:kevspeed wrote:Brown lighting wire.
Yayyyyyyy......tried that and it now works
Right......Its just the function button problem left!
I think i may have sorted the speedo but its just getting the timing right between the monsoons to try it out!
coaster wrote:It will need a resistor sparg plug otherwise the electrical interferance kills the speedo or so I was told and that worked for me. My speedo stopped working comming back from Belgium
Timexit17 wrote:I found the drive via cable didn't work either Kev and used the electronic drive instead (no cable).
https://www.sip-scootershop.com/en/prod ... r_50000270
kevspeed wrote:Seems odd that the rest of the speedo works with the normal plug...... Still, this is Lambretta we're talking, so anything is possible. I'll give one a try!coaster wrote:It will need a resistor sparg plug ............(
Users browsing this forum: No registered users and 61 guests
