Clutch spring length
Postby a-teamlambretta » Tue Jun 07, 2022 8:25 pm
I have two sets of clutch springs. One set is around 35mm tall and the other are 28 mm. The ones that are 35mm I presume are standard and the others are the stronger type is my theory correct?
Cheers Simon
a-teamlambretta
Re: Clutch spring length
Postby dickie » Tue Jun 07, 2022 10:10 pm
Take a look here. http://www.ilambretta.co.uk/forum/viewtopic.php?f=7&t=8675&p=75002&hilit=Clutch+spring#p75002
Near the end there's a list of springs I tested. You may get your answer there.
Generally speaking, thicker wire and longer free length means heavier. So if they both have the same thickness wire, the longer ones are probably heavier.
I'd also suspect that the 28mm ones are worn out and were originally much longer.
Postby ULC Soulagent » Wed Jun 08, 2022 2:35 pm
Mb=34.30/2.10/14.50
Mb=37.15/2.10/14.00
BGM STRONG 32.15/1.65/8.70
BGM MEDIUM 32.13/1.90/13.50
BGM SOFT 32.14/1.70/11.60
Above are the springs that I use and measurements are uncompressed length/ spring thickness/ compressed length
ULC Soulagent
Postby Warkton Tornado No.1 » Wed Jun 08, 2022 7:44 pm
ULC Soulagent wrote:Mb=34.30/2.10/14.50
Mb=37.15/2.10/14.00
Unless a material other than 'music wire' has been utilised, there's something strange if a spring wire diameter of only 1.65 mm can be stronger than similar springs of the same manufacture with greater wire diameters.... :?:
Postby ULC Soulagent » Thu Jun 09, 2022 7:48 am
Mb=37.15/2.10/14.00
Probably right WD1 :lol: I just measure what’s been sent in the bgm super strong package :roll:
ULC Soulagent
Users browsing this forum: No registered users and 51 guests
