oil throw washer
oil throw washer
Postby 59 lammy boy » Thu Nov 13, 2014 5:36 am
I've noticed that I don't have a oil throw washer on my drive side crank
Will it do any damage if it's left off
cheers
59 lammy boy
Re: oil throw washer
Postby Nobby » Thu Nov 13, 2014 6:52 am
Judging but your name is this a '59 engine?? In which case they wernt fitted with one and you can't actaully fit one without quite a bit of modification.
Nobby
Postby 59 lammy boy » Thu Nov 13, 2014 2:46 pm
Yes my lammy is a very early series 2 1959.
so I guess I don't need one ?
engine number is approx 9000 built and fitted to the series 2
59 lammy boy
Postby Nobby » Thu Nov 13, 2014 3:08 pm
Yeah s1's and early s2's dont have Them , it will be fine running as standard or mildly tuned top end, some people might advise against putting a high powered revvy kit on it without modifying the casing tho, what top end are you using?
Nobby
Postby 59 lammy boy » Thu Nov 13, 2014 8:15 pm
imola 186 top end
59 lammy boy
Users browsing this forum: No registered users and 91 guests
