Dellorto 30mm choke
Dellorto 30mm choke
Postby jonoy » Sun May 22, 2022 6:24 pm
I wanted to change choke cable today as the plunger is not fully closing when choke
is closed, no more adjustment
I’ve unscrewed the choke from top of card housing
but it’s remaking under tension and plunger will not
come out
Any suggestions please
jonoy
Re: Dellorto 30mm choke
Postby coaster » Sun May 22, 2022 7:31 pm
Nor sure what you mean, what sort of carb is it? The choke assembly should either be threaded directly into the carb body or if its a performance type (PHBH etc) it will be retained by a small screw. Either way the choke plunger should pull out easily.
Postby jonoy » Sun May 22, 2022 9:17 pm
Thank you for the reply
Sorted now
jonoy
Postby coaster » Sun May 22, 2022 9:20 pm
coaster wrote:Nor sure what you mean, what sort of carb is it? The choke assembly should either be threaded directly into the carb body or if its a performance type (PHBH etc) it will be retained by a small screw. Either way the choke plunger should pull out easily.
It was in the tread title Doh :? Glad you got it sorted
Return to Carburettors
Users browsing this forum: No registered users and 55 guests
