22mm Jetex Carb
22mm Jetex Carb
Postby srx600 » Wed May 11, 2022 10:00 am
I recently stripped the 22mm Jetex on my largely standard Li150 to check the jets and slide were correct. I have a reasonably good understanding of how carbs work (mainly Japanese) but was a bit surprised to see the slider did not have a needle. From what i have read the Jetex is a copy of a Dellorto so presumably that lacked a needle as well.
Is this common for two strokes of that era ?
srx600
Re: 22mm Jetex Carb
Postby Warkton Tornado No.1 » Wed May 11, 2022 2:31 pm
Yes. You'll find excellent confirmation of the mechanics of the SH range here:
http://www.ilambretta.co.uk/carb.html
Re: 22mm Jetex Carb
Postby Leotech » Sun May 22, 2022 1:34 pm
Warkton Tornado No.1 wrote:Yes. You'll find excellent confirmation of the mechanics of the SH range here:
I'm guessing,? But with the slide having no needle in the SH range the main jet has a greater influence over the full range of carburation than on a carb with a needle?
Leotech
Return to Carburettors
Users browsing this forum: Bing [Bot] and 52 guests
