by Specialcase » Thu Apr 28, 2022 2:02 pm
This is my first ser2 and I’m not sure how original this is? I thought they had a kill button and lock on the side. Anyone got an image of what it should look like? It’s a 1961 model
TIA
Spl
Specialcase
by nickw » Thu Apr 28, 2022 5:08 pm
I haven't a picture to show but the top hole should be a kill switch and the lower hole is the place for the steering lock. As can be seen the previous owner has fitted a key switch which instead of the kill switch.
nickw
by dickie » Thu Apr 28, 2022 5:09 pm
Is it spanish?
by Storkfoot » Thu Apr 28, 2022 5:13 pm
1960, Li 125.
by tim_mason » Fri Apr 29, 2022 4:46 pm
Or could it be a TV175
tim_mason
by Specialcase » Sun May 01, 2022 4:06 pm
No Guys it’s a ‘61 Li150 the livery is some Italian football team! it’s unsiezed so gonna have a go at getting it up and running, no battery, no key and I don’t think it’s an Innocenti ign lock (no number) so may have to get a new one. Clean tank & Carb “ Bob’s your Uncle Charlie’s your aunt” job done! This restoration Malachi is so easy!!
Specialcase
by Specialcase » Sun May 01, 2022 4:23 pm
While I’ve got your attention, I can’t work out how the side panels fit on as it came without the panels so I reckon someone’s taken em off. Can’t fine any images in sticky’s or on line - anybody help?
Spl
Specialcase
by duncan1958 » Sun May 01, 2022 9:59 pm
Normally have a bracket each side that is welded to the frame loop.
Sometimes the rear wheel side gets trimmed down to aid removal of the rear wheel.
duncan1958
by Specialcase » Wed May 04, 2022 9:48 am
Hey Duncan - would you have a picture of the brackets as I can’t seem to see any on mine. Could be that they were removed as the bike had no side-panels!
TIA
Spl
Specialcase
by Specialcase » Tue May 31, 2022 3:34 pm
Thanks for all the info ref ign lock. The side panel fixings have been removed hence it came without side panels, will have to get a new bracket and weld it on!
Ta all
Specialcase
by coaster » Tue May 31, 2022 4:16 pm
That looks like a brilliant idea, intended for the left side but looks like it could be fettled to fit both sides possibly
by Norrie Bodge » Tue May 31, 2022 5:50 pm
coaster wrote:That looks like a brilliant idea, intended for the left side but looks like it could be fettled to fit both sides possibly
They are at a different angle
But if you message Jon Betts (JB Fabrication)
I’m sure he can make you one for yours at correct angle
Norrie Bodge
by fiveo » Sun Jun 05, 2022 4:46 pm
I have used them and they work perfectly well.
fiveo
Users browsing this forum: No registered users and 91 guests
