Jeff t wrote:I think I have read every thread on the search looking for help but I’m Struggling to solve an issue with vibration when braking. Set up is a PM single disk anti dive, BGM dampers and I think progressive springs. I have checked every nut and bolt, had the headset off and nipped up the steering nut. Changed the angle of the anti dive up and down and put the dampers on the softest setting. Also had a DTI on the disk and it runs true.
Also done the bit rocking back and forward with the brake on and no play between the headset and leg shield, the stand on blocks no play in the front forks when I try and move the wheel.
The only area I can think of is the front end is pretty hard when I push down on the forks could stiff springs be an issue, as it’s a pain of a job thought I would get opinions first.
Oh and It’s a new build so always been like this any thoughts welcome.
Jeff t wrote:Thanks I’ll check the points you raise, rear shock is a protech and engine mounts are new think they where BGM. I have took the forks out and everything looks ok springs are definitely stiff though so will replace them even though they are new.
i was trying to measure the forks to make sure they are straight and aligned but not that easy although they do look ok by eye. The only thing I noticed was the tyre didn’t run true when I spun the wheel so will check the disk without the wheel when I put it back together, can’t see anything else.
Jeff t wrote:Stripped down the forks and one of the top fork link buffers is loose looks like the bolts have bottomed out, I am sure it won’t help but could that cause it?
