I am after one longer than this please. Does anyone know a supplier?
Jem Booth used to get them made but no longer does. Lincs Lambretta had one advertised on eBay with some less than complimentary feedback as to fit.
gaz_powell wrote:Paul
Andy Francis does a SS one, without one in my hand i would say longer the photo.
Gaz
gizmo wrote:I believe beedspeed do an extended one if your really desperate. Could you have a couple made. K2 customs or local engineering shop. Smile and act dumb and they might do it cheapish
shane BBoys wrote:Paul.
Lincs Lambretta are showing 2 x different sizes on Ebay.
https://protect-eu.mimecast.com/s/VNSdC ... ebay.co.uk
https://protect-eu.mimecast.com/s/1rWnC ... ebay.co.uk
Cheers Shane.
shane BBoys wrote:£6 ish I am sure you can stretch to that if not you can use it as a vase.
Cheers Shane.
Storkfoot wrote:Just to finish this thread off, I took a couple of pictures to show where I am now. I have two extenders fitted front and back and this gives a nice shallow loop over the inlet manifold and away from the plug cap.
As an aside, I do recommend rear brake cables that are nylon lined. I’d never had one until about 6 months ago. They make for a nice smooth action.
Oh and, yes, the next time the engine as out, I’ll get the stripped thread in the casing sorted
Storkfoot wrote:Routing of cable over TS1 inlet manifold and around spark plug. I have a short extended top hat in the frame at the moment (the same as my photo I suspect) but it could do with a tiny bit more loop to clear the plug. If someone made longer cable outers, you wouldn’t need to bother.
Users browsing this forum: Google [Bot] and 99 guests
