by d.godwin@virgin.net » Sun Feb 27, 2022 5:38 pm
Hi, I've bought a 2nd Gen Scootopia fuel tap. Apologies for the newbie question but what are the rubber seal and metal washer for? The rubber seal doesn't easily fit inside the nut, and I don't know where the metal washer might go?
d.godwin@virgin.net
by nickw » Mon Feb 28, 2022 3:27 pm
Lol, you've got me there. I haven't a clue. Usually rubber washer sits in nut as you have tried. Not sure what the metal washer could be used for
Hopefully someone else will have tried this tap
nickw
by Rich Oswald » Mon Feb 28, 2022 3:37 pm
Have you tried calling Scootopia?
by Warkton Tornado No.1 » Thu Mar 10, 2022 12:54 pm
I'm guessing that the washer is nominally the same size as the 'rubber' seal in which case it would most likely be a 'back up washer" intended to fit between the nut & the washer. It is normal practice to have such an arrangement on plastic waste plumbing fittings (under your sink etc) as it prevents the soft seal getting knarled up by the nut's recessed face during final tightening.
by stan63 » Fri Mar 25, 2022 7:18 am
I had the same issue so i e-mailed scootopia, they said throw the metal washer away, the rubber washer can go inside the nut if you want to use it, i didnt and the tap fit fine with no leaks.
stan63
Users browsing this forum: Google [Bot] and 91 guests
