Two into Three will go...
Postby Herbert » Wed Feb 16, 2022 12:07 pm
Hello all.
I am wanting to replace the Li s3 150 cc standard engine from an Eibar frame with an Li s2 Italian engine (186 cc already fitted with wide-type silent blocks). When I fit the engine to the frame tighten up the bolt, there is gap between the lug of the engine casing and the engine itself, and a lateral movement of the engine approx. 3-4 mm.
I obviously need to shim the gap to eliminate the engine's movement on the bolt and was wondering how folk have gone about this. Do I fabricate a shim to-fit, or is there something else you can recommend I use, please?
Any help or guidance will be much appreciated, and thanks.
H.
Herbert
Re: Two into Three will go...
Postby Storkfoot » Wed Feb 16, 2022 2:29 pm
Postby Tony Hart » Wed Feb 16, 2022 2:37 pm
Tony Hart
Postby Ranburetta » Wed Feb 16, 2022 3:01 pm
Is it not an issue with the frame cones?
Ranburetta
Postby hullygully » Wed Feb 16, 2022 3:28 pm
or the engine mounts not in far enough? :?
Postby Herbert » Thu Feb 17, 2022 10:36 am
Thanks all, very helpful.
I think the issue is due to a combination of:
- one of the engine bolt tubes in the mount is protruding slightly and the mount is n't in deep enough;
-I have a BGM shock fitted without shim; and
- the cones are n't the correct ones for the wide-type blocks.
Herbert
Postby gp200ts1 » Thu Feb 17, 2022 11:09 am
If I remember correctly the small engine mounts have flat sided cones whereas the large mounts have a chamfered edge to the cone and are slightly wider.
gp200ts1
Postby hullygully » Thu Feb 17, 2022 12:28 pm
I didnt know we had different engine cones :shock:
Postby gp200ts1 » Thu Feb 17, 2022 7:04 pm
hullygully wrote:I didnt know we had different engine cones :shock:
Page 261 of sticky’s spanner’s manual edition 3 or page 232 of edition 2.
gp200ts1
Postby Toddy » Thu Feb 17, 2022 9:13 pm
Every days school day ;)
Users browsing this forum: Google [Bot] and 75 guests
