Offset cones with flats
Postby Knowledge » Tue Feb 15, 2022 9:31 pm
The issue with offset cones has been nicely overcome by Casa’s kit of cones with D-shaped holes and a bolt/bar with a flat machined onto it. I also note that Glasgow Lambretta sell the same kit of parts under the banner of “Fortified”, but I guess they are not the Casa item.
I have the extra long engine mount on the k/s side, so the Casa/Fortified solutions are not suitable.
I have a capability to machine a flat onto my existing extra-long bolt/bar but I would need the Casa style cones with the D shaped hole. Glasgow don’t sell the cones separately and I anticipate the same response from any Casa supplier, so how could I manufacture some? Perhaps convert some “old-style” offset cones to have a flat within the hole?
Any thoughts?
Re: Offset cones with flats
Postby MickYork » Wed Feb 16, 2022 8:15 am
Probably easier to buy the cones and bolt, throwing away the bolt and making a new, longer bolt. The bolt would be easier to make than the cones.
Postby Leotech » Wed Feb 16, 2022 4:14 pm
They are ace, well worth it.
You could just drill and tap two stock cones and put grub screw in to stop them rotating, might be a bit fiddly to get the bolt in maybe but it would work and it's not like the motor comes out every day.
Leotech
Postby ROClarke » Thu Feb 17, 2022 6:33 pm
Why not ask your Casa supplier,don’t let assume make a ass out of you !
ROClarke
Postby Knowledge » Thu Feb 17, 2022 8:50 pm
Thanks for your replies.
I now have some cones coming from RLC. A good price, except for the postage, which was more than the cones.
I have also identified that Glasgow Lambretta and Harry Barlow have their own interpretations of the Casa solution.
I will machine my extra long bolt to suit the Casa cones and weld a slim nut on the end. The job should be a good’un.
Postby Knowledge » Mon Feb 21, 2022 9:03 pm
The Casa cones have arrived from Italy.
Next is a visit to John Howe at Jahspeed and to frighten my extra long bar with his Bridgeport mill.
More later....
