Only run on choke after 6 month stand up
Postby Liquidcooled » Sun Jan 30, 2022 2:21 pm
Lucky me got two TS1 225’s both running TMX35 carbs, long story short, after 6 months off road changed to new fuel, stripped Carbs and made sure both pilot jets were cleaned, and spray cleaned with carb cleaner. Both scoots will only run on choke, any advice to any particular channel needing clearing on a TMX, or others ideas welcome, pissed off was going to go for a spin in the lovely sunshine today.
Thanks David
Liquidcooled
Re: Only run on choke after 6 month stand up
Postby Fast n Furious » Sun Jan 30, 2022 3:30 pm
Main jets blocked most likely.
Postby hullygully » Mon Jan 31, 2022 2:52 pm
wouldn't have thought main jet bud, more likely still in the pilot jet area
does it get better the higher up the rev range?
Postby Liquidcooled » Mon Jan 31, 2022 9:43 pm
Yep , think it is the pilo
Liquidcooled
