Toddy wrote:I’ve used them Paul all I can say is the float mechanism seemed to start sticking in the tank on a couple on mine making the light stay on maybe ethanol? ….
Storkfoot wrote:Toddy wrote:I’ve used them Paul all I can say is the float mechanism seemed to start sticking in the tank on a couple on mine making the light stay on maybe ethanol? ….
Thanks, Paul. That’s what I feared. It’s a lot of effort to find it doesn’t work
ROClarke wrote:Never had a problem with them.
Maybe you bent the shaft fitting it,easy to do if you don’t take the tank fully out and run a 10mm drill up inside the tank to check the clearance.
I just put the light in my inside legshield toolbox rather than drill a speedo
trotsky wrote:Toddy wrote:I’ve used them Paul all I can say is the float mechanism seemed to start sticking in the tank on a couple on mine making the light stay on maybe ethanol?
Hi Paul, hope yer well mate.
Mine has done the same as Toddy's. The float plastic has gone hard & brittle. The warning light now just stays on. Hopefully it's something that will get addressed cos it's actually something that's useful for once![]()
Steve.
Leotech wrote:I had to remove one from a friend's Lamby recently, same thing got all sticky and light stayed on all time, he was new to Lambretta ownership, I said to him it's not exactly rocket science to remember how many miles you done and fill the tank when it gets low, you've even got reserve so you get a 15-20 mile grace period.
coaster wrote:Leotech wrote:I had to remove one from a friend's Lamby recently, same thing got all sticky and light stayed on all time, he was new to Lambretta ownership, I said to him it's not exactly rocket science to remember how many miles you done and fill the tank when it gets low, you've even got reserve so you get a 15-20 mile grace period.
It can be if you have more than one scooter on the go and you 'thik' you have a full tank but then run out of petrol in the middle of nowhere and then remember that it was the other one you filled up![]()
Users browsing this forum: No registered users and 84 guests
