petreol tap clearance around carb.
Re: petreol tap clearance around carb.
Postby coaster » Thu Dec 16, 2021 11:30 am
Storkfoot wrote:
rossclark wrote:Something like this might help
https://wheelspinmodels.co.uk/i/90014/? ... gI4_PD_BwE
Has anyone tried one of these from a model shop? If so, was it successful?
I've got one on the Jet Paul, cheap model boat one off ebay and works a treat, loctited the grub screws
Postby Storkfoot » Sun Dec 19, 2021 4:09 pm
Rich Oswald wrote:
Storkfoot wrote:Thanks for the replies. Plenty of food for thought.
I am going to start off by trying one of these:
https://www.andyfrancisscooters.co.uk/f ... 2452-p.asp
If it doesn’t quite work, I’ll probably get an extension welded on the lever too.
Those are the ones I use Paul.
Looks like this has worked but time will tell if it holds up. As usual, it took plenty of fettling.
Postby Storkfoot » Mon Jan 24, 2022 7:57 pm
I spoke too soon. Twice I loctited the grub screw in on the petrol lever side. First time it came loose but I spotted it had and loctited it in again. Second time, grub screw made a bid for freedom. That was with a small hole drilled in the lever to house the grub screw. I don’t think they can withstand the vibrations.
I am going to go back to the usual arrangement but with the MB extension.
Postby Rich Oswald » Tue Jan 25, 2022 4:54 pm
Rich'[/quote]
Looks like this has worked but time will tell if it holds up. As usual, it took plenty of fettling.[/quote]
I am going to go back to the usual arrangement but with the MB extension.[/quote]
Mine have been ok after Loctite, fingers crossed.
Return to Carburettors
