martyn dwane wrote:i tried turning the tap inwards towards the frame tonight, i can get the tap and rod to join up but when i try to turn the petrol on it pushes the carb " downwards" . so im gonna try a longer rubber manifold , some on the bay , but look like "radiator" hose, anybody ever used this ? .
I dont think the two items suggested will give me any more clearance .
rossclark wrote:Something like this might help
https://wheelspinmodels.co.uk/i/90014/? ... gI4_PD_BwE
Leotech wrote:Sometimes you need to weld a bit extra onto the tap part to get the lever part far enough away from the carb round the back. You need to cut a bit off the lever part too sometimes and file a new end on it and drill it etc to suit, then just angle it in the tank to miss everything.
I had to do one recently where a mate was using a big Mikuni carb, whoever built the Lamby before it ended up with me had put the fuel rod round the front and what a total arse it was to take off the carb to swap the jets etc when I was setting it up.
Storkfoot wrote:rossclark wrote:Something like this might help
Has anyone tried one of these from a model shop? If so, was it successful?
Storkfoot wrote:Leotech wrote:Sometimes you need to weld a bit extra onto the tap part to get the lever part far enough away from the carb round the back. You need to cut a bit off the lever part too sometimes and file a new end on it and drill it etc to suit, then just angle it in the tank to miss everything.
Thanks for that. Food for thought. It’s not far out and I am sure some folk would just live with it but the lever is vibrating against the back of the carb and the tap mechanism is so notchy it makes me nervous that at some petrol station far far away, it’ll break.
Cgt75b wrote:Storkfoot wrote:rossclark wrote:Something like this might help
Hi Paul
I tried one from a recognised dealer and tbh it fell to pieces. So I bought a piece of brass off eBay which is soft enough to drill = job done.
Storkfoot wrote:Thanks for the replies. Plenty of food for thought.
I am going to start off by trying one of these:
https://www.andyfrancisscooters.co.uk/f ... 2452-p.asp
If it doesn’t quite work, I’ll probably get an extension welded on the lever too.
