Warkton Tornado No.1 wrote:I think that the standard OEM components are far better than we give them credit for. For instance, as far as I know, Dave Webster used OEM type front dampers for his racing career, even though alternatives were available. I can vouch for the fact that the Kawasaki type steering dampers are dire....
As far as I am aware, there are not any aftermarket dampers - front or back - with truly independent control adjustment for compression & rebound. The rebound always seems to be a product relative to compression. I hope to be corrected on this.....
Leotech wrote:If you set the static sag to half the available travel by the time you are sitting on the machine it will nearly be bottomed out.
Rider sag, with rider, should be about 25-30% of available travel. Static sag, no rider, should be about 5-10%.
Users browsing this forum: Baidu [Spider], Google [Bot] and 44 guests
