RT gearing
RT gearing
Postby Toddy » Wed Nov 24, 2021 11:47 am
Just in the process of building one for a mate , solo rider , 30mm dellorto and clubman looking at a good touring set up,what are people running in theirs ? Cheers
Re: RT gearing
Postby Rich Oswald » Wed Nov 24, 2021 12:07 pm
Toddy wrote:Just in the process of building one for a mate , solo rider , 30mm dellorto and clubman looking at a good touring set up,what are people running in theirs ? Cheers
Indian GP200 box, 19/46 in my RT230 reed, but you'll know that! ;)
Re: RT gearing
Postby Toddy » Wed Nov 24, 2021 12:12 pm
Sorry small block RT 195
Re: RT gearing
Postby Rich Oswald » Wed Nov 24, 2021 12:29 pm
Ah ok! ;)
Re: RT gearing
Postby Rich Oswald » Wed Nov 24, 2021 12:44 pm
Just done a search on the RT Facebook group and most are running LI150 Box with 16/46. One running 17/46 but I reckon that might struggle on hills or headwind.
Re: RT gearing
Postby nsaints » Wed Nov 24, 2021 1:36 pm
Mine is running an Li150 16/46, & went around the last Derby 150 fine. This is despite others telling me the gearing is wrong for my configuration.
RT195, MB version 4, 25mm PHBL, modified standard airbox
Edit. Corrected the typo front sprocket size to 16.
Didn’t enjoy 4.89 on the Kendal rally. Hills must be steeper ?
Somewhere near 5 would be better
I’ll change my gearing after the NRR this weekend.
nsaints
Re: RT gearing
Postby Mike-Allen » Wed Nov 24, 2021 1:43 pm
My series 2 RT195 with 30phbh, 60x110 crank & V4 BGM runs the AF5 gearbox 35 tooth version 18/47
Mike-Allen
Re: RT gearing
Postby Meds » Wed Nov 24, 2021 5:45 pm
I’m more a fuller figured gentleman and run it at 4.95 on a pacemaker box.
Great all rounder - it’s my go to scoot for the twisties and hills.
BGM clubman and 30 delly - non Reed
Meds
Re: RT gearing
Postby ULC Soulagent » Thu Nov 25, 2021 7:53 pm
On my S2 Rt195 piston port, 28 delly, bgm mk1 , li 150 box 16/46
On the special Rt 195 reedvavle, 25 delly, bgm mk4, sx200 box 15/46
Both decent setup with only very steep hills and headwinds killing top end
ULC Soulagent
Re: RT gearing
Postby Toddy » Thu Nov 25, 2021 9:40 pm
Thanks gents
Re: RT gearing
Postby lozmondo » Fri Nov 26, 2021 6:39 pm
piston port, 60x110 crank,30mm, BGM v3
LI125 17x46 (5.01 final drive ) pulls lovely tops out above legal speed limit according to GPS
Great all round motor
lozmondo
Re: RT gearing
Postby Nigel. S » Fri Nov 26, 2021 11:23 pm
LI150 15/46, 30mm, v4 box. 60/110
Had 16/46 with a scootopia box and didn't like it.
Intend to put the 16 back on now it has the v4.
Still good as it is though.
Nigel. S
