Top shock mount repair
Postby Storkfoot » Fri Mar 05, 2021 7:33 pm
Okay, this is a Vega but the same principles will apply :D
The threads towards the end are now beyond repairing with a die. This is an old photo of the mount.
The diameter of the end of the shock mount is only 12mm which doesn’t give too much scope to repair it with a stepped stud of, say, 10mm/12mm.
Any of you any engineering experience of how I can replace or repair the rear shock mount please?
Re: Top shock mount repair
Postby Warkton Tornado No.1 » Fri Mar 05, 2021 11:40 pm
What is the thread?
If it is, say, M12 x 1.5 (just less than 17 TPI) then you might manage to run a 7/16" BSF (18 TPI) die down it.
Postby Storkfoot » Sat Mar 06, 2021 10:17 am
M12 x 1.75.
Postby Warkton Tornado No.1 » Sat Mar 06, 2021 3:48 pm
In that case, 7/16" BSW is close with 14 TPI. However, please check out the technical details before committing :D
If I'm right, a split die is the way to go, gradually increasing the cut to produce a tidy thread. If I had one, I'd lend you a die, but @ £3.25 including P&P:
EBay:271557984130
Postby Storkfoot » Sat Mar 06, 2021 8:22 pm
Warkton Tornado No.1 wrote:In that case, 7/16" BSW is close with 14 TPI. However, please check out the technical details before committing :D
EBay:271557984130
Thanks. I’ll give that some thought.
Postby Storkfoot » Fri Oct 29, 2021 5:56 pm
Finally, I got round to taking the frame to the engineers. They propose to cut it off and make another longer replacement. When I say longer, I mean more thread as anyone with a Vega will know there are precious few threads visible once you have the shock absorber fitted.
I’ll post a picture when I get it back.
Postby Storkfoot » Tue Nov 23, 2021 9:36 pm
Just need to dress the end of the thread.
Postby coaster » Wed Nov 24, 2021 1:36 am
I could very well be wrong but I looked at the shock stud on mine today and I'm fairly sure that the boss is either plastic or hard rubber on mine :?
Postby Storkfoot » Wed Nov 24, 2021 10:08 am
coaster wrote:I could very well be wrong but I looked at the shock stud on mine today and I'm fairly sure that the boss is either plastic or hard rubber on mine :?
That’s just a plastic cover, mate. It does perform a function though, it keeps the inner bush of the shock absorber from flexing.
Users browsing this forum: Google [Bot] and 95 guests
