TV 175 series 3 RS Type.
Postby Kirk St Moritz » Thu Nov 06, 2014 10:38 am
TV175 series 3 rebuild taking a little inspiration from my Audi RS4.
Starts here.
Kirk St Moritz
Re: TV 175 series 3 RS Type.
Postby Kirk St Moritz » Thu Nov 06, 2014 11:46 am
Strip down!
This TV had an RB engine, six plate clutch with packing plate etc etc. Also a hydraulic outboard brake. All of which were sold.
The intention of returning the engine back to somewhere near standard for simple reliability and a standard front disc brake too.
Kirk St Moritz
Postby Toddy » Thu Nov 06, 2014 1:12 pm
Are you having a similar Paint scheme on this one Craig ?
Postby Mr G in NYC » Thu Nov 06, 2014 2:09 pm
Original spec perhaps ??? G 8-)
Postby Kirk St Moritz » Thu Nov 06, 2014 2:39 pm
Very nice G! That is my favourite colour for a TV175 series 3.
My TV is already painted. I did post some stuff on it before the forum crash. I'll start the thread from the beginning again and share pics of the process!
But it has an S Type- ish theme to it Toddy with some similarities to the DL 125 on the other thread!
Kirk St Moritz
Postby Kirk St Moritz » Thu Nov 06, 2014 3:32 pm
The previous owner had kept some of the original parts from before the RB engine build. These were included in the sale as I wanted to reuse them! This includes the barrel, head, crank, gearbox ect.
Bare engine casing needed cleaning. I just used WD 40 and wire wool on it.
Original engine parts.
Started with the new bearings seals and fitting the gearbox.
Managed to find a NOS disc brake too!
Kirk St Moritz
Postby Kirk St Moritz » Thu Nov 06, 2014 3:40 pm
I had to find a set of chrome ring legshields to fit and a nice man from Paris helped me out.
Then I started a dry build.
The frame also needed the battery tray replacing!
And off it went for paint after everything was blasted!
Kirk St Moritz
Postby Mr G in NYC » Thu Nov 06, 2014 5:01 pm
Nice.....you can't beat original Innocenti parts..looking good 8-) G.
Postby Kirk St Moritz » Thu Nov 06, 2014 6:48 pm
Mr G in NYC wrote:Nice.....you can't beat original Innocenti parts..looking good 8-) G.
Agreed mr G, but I have used a few non standard parts too! Good quality ones though.
Some pics of the frame repairs which were necessary.
Then prep work for paint.
Primer
Colour. Audi Daytona grey.
Kirk St Moritz
Postby Kirk St Moritz » Thu Nov 06, 2014 9:23 pm
Soooo, I picked up some of the paintwork and began to build it.
Engine casing going in.
Tank rear mudguard.
Built the hub.
Built the forks.
Cables etc
Tyres on rims fitted.
Kirk St Moritz
Postby scooterstu » Fri Nov 07, 2014 2:02 pm
Looking fantastic, keep them coming
scooterstu
Postby Mr G in NYC » Fri Nov 07, 2014 2:43 pm
scooterstu wrote:Looking fantastic, keep them coming
Agree + one G 8-)
Postby Scooterslag » Fri Nov 07, 2014 10:10 pm
very nice
Postby Kirk St Moritz » Sun Nov 09, 2014 1:10 am
Thank you!
Moving on with some more pics........
Paintwork coming together....,
Custom badge
Bodywork going on.
Original locks
Smiths chronometric speedometer.
Home nickel plating.
Seat choice from Rimini Lambretta Centre.
More pics later.
Kirk St Moritz
Postby Kirk St Moritz » Sun Nov 09, 2014 12:50 pm
Turned my attention to the top end!
Original nos Borgo piston
Nos head.
Correct inlet manifold for standard carb
Bit of black paint to tart the barrel up after rebore.
Carb stripped cleaned and rebuilt
Kirk St Moritz
Postby Kirk St Moritz » Sun Nov 09, 2014 12:56 pm
Smiths rev counter drive cable routing through the stand crossmember.
Rimini Lambretta conversion to the sidecasing! Spot on!
Checking clearance of the clubman exhaust.
And the rear footboard.
Fitted a new BGM rear shock with a matching red spring.
Kirk St Moritz
Postby Kirk St Moritz » Sun Nov 09, 2014 2:18 pm
Next, the problem of where to mount the Smiths rev counter.
I wanted it as close to the headset as possible, allowing the straightest simplest route for the cable. So this is the position I wanted it, but with nothing to mount it to I had to design a bracket!
Careful cos this is where it gets boring for some people who will remain nameless!
Made a cardboard template.
And a nice man called Jon Betts ( JB fabrication) made me this steel laser cut bracket!
Checked the fit an I'm well happy.
Just needs painting satin black!
Kirk St Moritz
Postby Paulnobodyimportant » Sun Nov 09, 2014 2:51 pm
Excellent Craig
Paulnobodyimportant
Postby Cgt75b » Sun Nov 09, 2014 7:12 pm
Agreed bloody lovely, top notch stuff.
Postby dave411 » Sun Nov 09, 2014 7:44 pm
German engineering at its best !!!!!!
Love the colour scheme,Love Audis.Bring it on :P :P
dave411
