Expansion chamber for RT195 cylinder
Postby Pompeydave » Mon Oct 25, 2021 7:42 pm
Hi all, I've decided to change my latest engine rebuild from a Quatrini 210 kit to an RT195. Looking for an expansion pipe as I know this sounds daft I've never had an engine with one fitted and I do like the peaky sound of a good pipe! It'll be a reed valve conversion with a 28mm carb, five speed box and a SIP Vape ignition system. Not looking for anything too wild, so a good all rounder is what I'm after really. Any recommendations please?
Pompeydave
Re: Expansion chamber for RT195 cylinder
Postby Toddy » Mon Oct 25, 2021 9:45 pm
Just a question what changed your Mind from quattrini to RT there’s a bit of difference?
Postby Pompeydave » Mon Oct 25, 2021 10:40 pm
Yeah, good question. I read several posts on various forums from people saying how all or nothing a kit it is. Sticky’s latest kit book shows dyno graphs that are just the opposite though in that there is a fairly wide power band. Dunno, what do you think?
Pompeydave
Postby Toddy » Mon Oct 25, 2021 10:45 pm
Pompeydave wrote:Yeah, good question. I read several posts on various forums from people saying how all or nothing a kit it is. Sticky’s latest kit book shows dyno graphs that are just the opposite though in that there is a fairly wide power band. Dunno, what do you think?
I was wary when I decided but I must say I really like mine geared it for touring (4.4 ) more than balls out pulls like a train and keeps going scary at times :lol: rideable round town as well , the cost wasn’t cheap with the usual bits clutch , crank , pipe etc but imho well worth it I like riding it better than my TS , done @3,500 miles so far all good
Postby Pompeydave » Mon Oct 25, 2021 11:31 pm
And is that an RT, or a Quatrini you’re talking about?
Pompeydave
Postby Toddy » Mon Oct 25, 2021 11:31 pm
Pompeydave wrote:And is that an RT, or a Quatrini you’re talking about?
Sorry quattrini
Postby Pompeydave » Mon Oct 25, 2021 11:50 pm
Arghhh! Now you’ve got me feeling torn between the two!
Pompeydave
Postby lozmondo » Tue Oct 26, 2021 5:49 pm
I.ve an Rt (piston port not reed valve) and a Quattrini, the Rt is an excellent kit without doubt. However, the Quattrini does everything the RT does...and more,Ive run it with a box pipe and it was a really sedate ride with a ton of low down grunt. Now with an expansion its still great low down but has a massive grin factor when you wind it up!
adding the reed to the RT makes it possibley a bit more expensive as well.
Either way both good kits ;)
lozmondo
Postby Pompeydave » Wed Oct 27, 2021 10:12 am
Hmmm, I’m in two minds now re the RT. What expansion are you using lozmondo?
Pompeydave
Postby lozmondo » Sun Oct 31, 2021 7:34 pm
its a reworked Taffy copy, but will probably end up with one of Darrel taylors JL pipes when he gets more in
lozmondo
Users browsing this forum: Baidu [Spider] and 45 guests
