This is an aftermarket exhaust. It’s a clamp type tailpipe as you can see. My question- should the clamp not be at 180 degrees to the road, if you see what I mean?
I did tell you it was an anorak question
humble wrote:Yes, I think it should be at 180 as you suggest, vertical to scooter if that makes sense?
hullygully wrote:its not the clamp but the tail pipe you're asking about?
it wouldn't make any diff @ all bud apart from its aesthetics
nickw wrote:Lol glad that was explained. I have the same problem with a recent GP restoration with the (same?) exhaust pipe. Unfortunately the exhaust is what I thought the closest to original and didn't realise until it was fitted.
Storkfoot wrote:I did try and find a Tutto exhaust in the UK at the outset. I couldn’t, so went for the Scootopia one. If or when I get a response from Scootopia, I’ll let you know.
That looks a lovely SX150, TT.
TurboTrev wrote:The Scootopia version had quite an angle on it so I went for a Tutto on my SX150 and it's just about straight.
Users browsing this forum: Baidu [Spider] and 144 guests
