Liberty - 1961 series 2 LI 125
Re: Liberty - 1961 series 2 LI 125
Postby pazwaa » Wed Nov 05, 2014 9:47 pm
Nigel. S wrote:Somehow missed this so just read whole thing from start. Great read. Always good to read these DIY rebuilds. Good luck with it.
From my own experience only, I would pay a bit more and buy decent components for forks rather than a "rebuild kit". ones I had were woefully bad. Holes off centre through bushes, nuts/bolts with unsymetrical heads, just complete sh1te, but as I say that was my experience. It is tough if you're on a budget and you are confronted with a cheap option for something that costs double elsewhere. But there will normally be a good reason why prices are so different. Hope that helps, don't mean it to be a downer. ;)
Washers, believe it or not the lower ones were what was in the kit, top ones innocenti originals, guess which I used. And the dealer told me on the phone that they check all the components of their kits, check for what I wonder! Also balls on end of rods were wrong size (despite ordering kit with small balls :shock: ) and didn't fit snug into fork links and look like they'd been made with a blunt plastic spoon! Maybe it was just my choice of dealer that was the prob, can't remember who without going through receipts but hey, I'm over it now :lol:
Anyhow, keep at it. Great thread :D
Hi Nigel. Thanks for the feedback, nice to hear from new people :)
Some interesting washers there, definitely look like they've been cut out with a knife and a fork :o
On the back of your experience I'll probalb spend a bit more money from a decent supplier :D
Matt
pazwaa
Postby pazwaa » Fri Nov 21, 2014 1:29 pm
very small (annoying) amount of progress made this week.
good news first, all my parts came back from the blasters looking smooth and primed.
good i thought, time for a dry build.
first thing was i'd forgot to remove the chrome ring, think thats the right phrase, from the stem. oh my, what a job that was
heated the top of the stem with an electric heater first
25nb tube down the stem
and the inner bush popped out easy. then the chrome ring. electric heater just wasn't warming the steel enough, so gas axe was employed
took me an hour of warming, tapping, warming, tapping. eventually the stubborn so-and-so came out.
good i thought, time for a dry build. went to put the legshield on and this is fixed with M5 bolts, not a common engineering size, the engineering shop has every sized bolt M6 and upwards, but no M5's :evil: so fitting kit ordered ;)
also seems i have the removable right side floorboard bracket missing, so need one of those :evil: if anyone has one kicking around, please pm me. if not, ill make a temporary one.
hopefully a complete dry build shortly.
onwards and upwards, very slowly :lol:
matt
pazwaa
Postby Toddy » Fri Nov 21, 2014 3:23 pm
Good to see you making progress , theses always something missing lol take your time and enjoy it :D
Postby pazwaa » Sat Nov 22, 2014 10:06 pm
Toddy wrote:Good to see you making progress , theses always something missing lol take your time and enjoy it :D
Cheers toddy. Yep, just need to learn a bit of patience :D
pazwaa
Postby pazwaa » Wed Nov 26, 2014 1:48 pm
looked at starting the dry build last night, but didn't get very far.
need to straighten this support
a weld repair required on the leg shield
and i think this tab needs flattening. can anyone confirm this?
my fixing kit arrived :)
but no instructions so a bit confused by this lot :o
there's supposed to be the fixings for the legshields, footboards and mudguard. Can anyone guide me as to whats what? or point me to a guide/document showing how to fit the parts?
cheers
matt
pazwaa
Postby Tractorman » Wed Nov 26, 2014 5:18 pm
Hi Matt,
one of us as put the little inner front mudguard on the wrong way around. Anyone tell me which is the correct way, please?
http://i1064.photobucket.com/albums/u37 ... 32E3F7.jpg
Postby Toddy » Wed Nov 26, 2014 7:37 pm
Tractorman wrote:Hi Matt,
Short bit and holes to the front , I think :D
Postby pazwaa » Wed Nov 26, 2014 11:25 pm
Tractorman, I think toddy is right, mine is the wrong way round :o
Matt
pazwaa
Postby Tractorman » Fri Nov 28, 2014 10:21 am
Thanks Toddy, I thought it was that way then you access the horn casting bolts through the holes.
Postby pazwaa » Thu Dec 18, 2014 1:36 pm
finally brought the old girl home
get the madness of christmas over and then begin the dry build in the comfort of my back garden :)
pazwaa
Postby pazwaa » Wed Dec 31, 2014 11:42 am
Got a bit done last night, with the aid of two enthusiastic helpers
Started the dry build, temporary fixings, and a few bent, dented and twisted panels
Offside footboard is bent at the back
And twisted down the side
The gap between the legsheild and the footboard is quite good, one or the other needs centreing though
Near side footboard is twisted too
Again, the legsheild/footboard gap is quite good
Side panel gaps to the frame vary a lot along their length
Not too bad at the front
Varies in the middle
And bad at the back
A lot of straightening needed on these :shock:
There is also a gap between the offside side panel and the footboard
Is this normal? Other than the handles at the back, are there other ways to hold the side panels on?
Legsheild is twisted
So, a lot of straightening/aligning to do ;)
But she's starting to look like a scooter :D
Any advice/tips on fixing any of this would be gratefully received.
Matt
pazwaa
Postby soullad » Fri Jan 02, 2015 12:03 am
Looking good
You have an early right hand rear floorboard, the inside edge of which should align approx with the panel when looking from above, as in the picture you have taken. So don't worry if it looks a touch unusual. The later rear floorboards had the extra metal presumably to help with air circulation and /or rain water channeling?
Keep the pics coming
soullad
Postby xenia1 » Fri Jan 02, 2015 12:43 am
Good to see youre doing a dry build, so many just dont bother.Please dont take this as a criticism as its certainly not meant to come across as that ;) ...but...the legshields and footboards look like theyve seen better days and the time and money spent trying to get them into a shape fit for painting would probably be better spent on replacements in better condition. The side panel gaps could be caused by the frame being transported upended causing the sides of the loop to splay outwards but the Indian side panels could have a part to play here and Innocenti originals would be a better option and would add value to the finished product. Getting the frame jigged professionally would also be a good idea and would give a starting point for good panel gaps plus give you some peace of mind.
Not telling you how to suck eggs and as mentioned not a criticism..
Andy ;)
xenia1
Postby pazwaa » Fri Jan 02, 2015 10:59 am
soullad wrote:Looking good
Thanks Ian, good to know I heading in the right direction ;)
Matt
pazwaa
Postby pazwaa » Fri Jan 02, 2015 11:12 am
xenia1 wrote:Good to see youre doing a dry build, so many just dont bother.Please dont take this as a criticism as its certainly not meant to come across as that ;) ...but...the legshields and footboards look like theyve seen better days and the time and money spent trying to get them into a shape fit for painting would probably be better spent on replacements in better condition. The side panel gaps could be caused by the frame being transported upended causing the sides of the loop to splay outwards but the Indian side panels could have a part to play here and Innocenti originals would be a better option and would add value to the finished product. Getting the frame jigged professionally would also be a good idea and would give a starting point for good panel gaps plus give you some peace of mind.
Andy ;)
Hi andy
No worries, glad your offering advice ;) you are correct, the legsheild and footboards are in a bad way, the panels too, to a lesser extent. They were all cheap, and I'll give them a go, I have no time limit for this project, so hopefully learn a bit along the way. I'm taking her back to a fabshop Tuesday and have a go at straightening the panels out with some clamps, heat and a hammer. Hopefully I can get them something like. If not, as you say, new panels will be needed.
I gave the legsheilds a bit of tlc last night and managed to get the twist out, so,just the lumps, bumps, dents and rips to sort now. ;)
What does frame jigging do?
Any comments, suggestions, even criticism most welcome, this is my first time at this, and others advice is most helpful ;)
Matt
pazwaa
Postby pazwaa » Wed Jan 07, 2015 1:22 pm
Bit of progress last night
A big work bench, big clamps, a small and large hammer incorporated, and straightening has begun :)
support struts straightened and levelled
split in the legsheild beginning to disappear (till the grinder packed up) :(
and one footboard straightened and split welded, fits loads better now
finish repairing the legshield, grinder allowing, next week and the other footboard. then onto panels :o
pazwaa
Postby Toddy » Thu Jan 08, 2015 7:25 am
Nice work so far :D that shed you built in the garden is quite decieving from the outside ;)
Postby duncan1958 » Thu Jan 08, 2015 10:11 am
The whole approach you have is spot on and an inspiration to anyone who has the doubt about starting a project of this size.
I have every confidance in the fullness of time your first project turning out well and then leading to another.
duncan1958
Postby pazwaa » Thu Jan 08, 2015 1:17 pm
Toddy wrote:Nice work so far :D that shed you built in the garden is quite decieving from the outside ;)
Cheers Toddy.
:D yep, its like the tardis, can get a fork lift truck in there :D Unfortunately when i need to weld and bend, my sheds no good, so off to a friends engineering works. ;)
pazwaa
Postby pazwaa » Thu Jan 08, 2015 1:21 pm
duncan1958 wrote:The whole approach you have is spot on and an inspiration to anyone who has the doubt about starting a project of this size.
Thanks duncan, means a lot :)
i'm slightly more blessed than the average joe as i started my working life as a welder, and been in engineering ever since, which helps massively. i also have a local engineering company that let me rent space cheaply and use their gear.
pazwaa
Users browsing this forum: No registered users and 184 guests
