TV2 front brake
TV2 front brake
Postby dickie » Fri Sep 10, 2021 2:49 pm
I'm thinking of fitting a TV2 front brake. Do I need some weird ultra rare fork links or can I use SX type?
Re: TV2 front brake
Postby bike grim » Fri Sep 10, 2021 5:45 pm
SX type are fine
Re: TV2 front brake
Postby tim_mason » Fri Sep 10, 2021 7:47 pm
Any disc links will do ,
tim_mason
Re: TV2 front brake
Postby dickie » Sat Sep 11, 2021 6:09 am
Thanks gents. Unfortunately someone else bought it anyway.
Re: TV2 front brake
Postby Warkton Tornado No.1 » Sat Sep 11, 2021 4:41 pm
See PM!
Re: TV2 front brake
Postby Leotech » Sun Sep 12, 2021 4:29 pm
S1+2 TV links are different from S3 type in the same way as S1+2 drum links are different from S3 drum links.
In practice you can use S3 type disc links though it will change the handling characteristics of the scooter.
Leotech
Re: TV2 front brake
Postby Warkton Tornado No.1 » Mon Sep 13, 2021 11:21 am
Leotech wrote:S1+2 TV links are different from S3 type in the same way as S1+2 drum links are different from S3 drum links.
I got a bit confused by this, so I read it again & it is correct :oops:
(My confusion came about because S3 links are all of the same geometry as we all know. Hence the TV175 S1-2 links being highly sought for the effect upon the front end in raising the forks relative to the wheel, ostensibly to allow better clearance in the event of an hydraulic slave cylinder being functional on a generic type disc brake)
Just to clarify, an S3 (quite rightly) fitted with S3 fork links can have potentially any S1-3 front brake fitted (that will fit*) & the geometry/handling characteristics will remain the same.
* bearing in mind the differences in the RH link, either pin slot or screw slot
Re: TV2 front brake
Postby bookertmgs1 » Mon Sep 13, 2021 4:04 pm
If anyone does have a set of TV2 links for sale then please let me know
Continuing my appalling luck on ebay - I missed a set a month or so ago.
bookertmgs1
Users browsing this forum: Baidu [Spider], Google [Bot] and 86 guests
