by Stesjh » Fri Aug 27, 2021 10:45 pm
So I am having trouble getting my SIP speedo to record speed and mileage, first speedo suddenly started to register low speed. Thought it was a fault with speedo so replaced. Now no speedo or mileage everything else works. With headset off and wheel spinning cable rotates fine. Any advice most welcomed
Stesjh
by missing lynx » Sat Aug 28, 2021 7:58 pm
Have you set the speedo for cable or external drive which ever you're using?
by Stesjh » Sun Aug 29, 2021 10:00 am
missing lynx wrote:Have you set the speedo for cable or external drive which ever you're using?
Yes all set up correctly, very frustrating
Stesjh
by Covboy » Mon Aug 30, 2021 9:41 am
Is it the magnetic sensor? I changed mine for the electric drive version as the magnetic one was in consistent - when the scooter is off the stand and the front under load or off load when accelerating the sensor changes position in relation to the magnet ….
Users browsing this forum: Google [Bot] and 64 guests
