Front dampers
Front dampers
Postby Tractorman » Wed Aug 25, 2021 12:12 pm
Do any front dampers work both ways? Looking for some that will also dampen on braking.
Re: Front dampers
Postby dickie » Wed Aug 25, 2021 8:12 pm
I really can't remember what make they were, but I bought them from a shop in East Yorkshire that many seem to have problems with (am I still within forum rules?).
They were polished stainless steel and the only ones I've ever encountered that damped significantly in both directions.
Re: Front dampers
Postby lofty » Thu Aug 26, 2021 9:21 am
old stylee 'kawasaki' steering dampers maybe?
lofty
Re: Front dampers
Postby Rich Oswald » Thu Aug 26, 2021 10:02 am
lofty wrote:old stylee 'kawasaki' steering dampers maybe?
They definitely only damp one way!
Re: Front dampers
Postby missing lynx » Thu Aug 26, 2021 11:47 am
I would look at mini motorbikes, quads or carting, I did start looking myself it's just finding the right dimensions that's the hard bit
Re: Front dampers
Postby dickie » Thu Aug 26, 2021 1:02 pm
Then they're not steering dampers. Or they're knackered.
Re: Front dampers
Postby Rich Oswald » Thu Aug 26, 2021 4:00 pm
Yes You are right, mine WERE knackered. :lol: :lol:
Re: Front dampers
Postby Warkton Tornado No.1 » Fri Aug 27, 2021 11:25 am
OEM dampers work in both directions but predominantly in rebound. They do actually control compression a small amount but their main function is to prevent oscillation or 'pogo-ing'. I took a knackered one to bits to see how they worked & reckon that some would be rebuildable, in which case a heavier weight oil springs to mind :idea:
The standard OEM Innocenti & Serveta dampers are far better than they are given credit for. Dave Webster used them extremely successfully which, IMHO is great testament. Of the alternatives, Bitobo aftermarket dampers intended for Vijay are highly prized & also were utilised with great success by another race champion, Charlie Edmonds.
The worst front ends I have ever tried (other than badly set anti-dive) are no dampers @ all closely followed by the Kawasaki type steering dampers.....
I'm just saying :roll: but perhaps with a sidecar things may be completely different. I wonder if Serveta might be worth a try, but the forks & links are somewhat specific.
If this response has put you in a quandary, I apologise, but I found the Kwak type unbelievably dire, though I suppose I have had to be a bit of a 'chassis man' having fell off so many times :oops:
I have no idea of the practicality, but I could lend you a set of bare Serveta forks, links & dampers I'm otherwise hoarding......
Re: Front dampers
Postby dickie » Fri Aug 27, 2021 11:56 am
I'd expect a steering damper to be appalling on suspension. Generally speaking any compression damping should be much less than rebound which is trying to counteract the spring energy and the consequent kinetic energy as the front bobs up.
It's a good approximation to think of compression damping as helping to make the spring action more linear. With spring only on compression, the rate rises rapidly as the spring compresses. With a damper, you can run a softer spring.
I've had good results in the past by simply using heavier oil in forks.
Users browsing this forum: Google [Bot] and 87 guests
