Con-Fused
Con-Fused
Postby Bilko » Fri Jul 16, 2021 4:46 pm
Finally got the lights, brake light, horn, working last night but when I switched from high beam to dip or the other way round it would blow the fuse.
Today it now blows the fuse if I try to switch on the lights via ignition switch. Although the speedo, horn, brake light will work (until I turn the ignition switch)
I’ve looked over the connections and everything seems insulated correctly.
Any ideas?
Bilko
Re: Con-Fused
Postby Warkton Tornado No.1 » Fri Jul 16, 2021 11:54 pm
Rectifier/regulator not functioning or shorted through? Or has it been inadvertently not earthed (or wired in parallel via another link)?
If fuses are correctly rated to do their job in blowing, then the electrical power generated is uncontrolled if not regulated.
Re: Con-Fused
Postby Bilko » Mon Jul 19, 2021 10:09 am
Thanks WT.
With help I found one of the problems. One of the two screws in the light switch housing had pinched the wiring.
Bilko
Re: Con-Fused
Postby Warkton Tornado No.1 » Mon Jul 19, 2021 5:08 pm
That's likely your only problem.....with the Lambretta , obviously :lol: :lol: We've all seen your on board video :shock:
Momentary short to Earth on operating the switch got worse & worser....
Users browsing this forum: No registered users and 86 guests
